Rix
100 TW
Zombiess, thanks for stepping in and clarifying that. Learning more everyday. ///Edit/// The cromo is up over 90%? That is indeed impressive. The 5403 is in the low 80s, the 5404 and 5405 would only be slightly higher, but wouldn't be out of the 80s for sure. For awhile, Justin had the cromo V1 on his simulator, but not officially. He posted the data based on input. He called it the general 5004. A hub motor with a 50mm wide stator and 4 turn wind on the stator. Its been off for a while now. I suspect it was because he hadn't done complete testing to meltdown. As far as innovation goes, the cromotor is superiour for two simple reasons, the axle being a 16x10, and the wider stator. That increased surface area translate directly into durability and power to the ground. I wish I could get the cromo with that axle and 162mm wide faces. I could modify the torque blocks easy enough to except the bigger axle and it would slide right in with no spacers. Still not impossible to do with the current 145mm wide axle though. Just need spacers.
Rick
Rick
