Chalo said:
Too bad you didn't try better rim brakes first. Good, competently set up linear pull brakes with Kool Stop pads will categorically outperform BB5 brakes while costing half as much. This is especially true with large diameter wheels like 29". When the wheel gets bigger, the rim brake does too... but the disc brake stays the same size and loses leverage.
I think that most of people's overestimation of bicycle disc brakes is due to never having tried making rim brakes deliver their potential.
YES! And that full potential can often be very elusive! Of course todays technology of Kool Stops, cables and such, with the high tech markets of availability, certainly has made it much better than days past. That 29er, surprisingly, had the worst I'd ever seen or experienced on a bike! But ya typically get what you pay for, and the base bike was rather cheap! Ugh! It was certainly costly in making a disk conversion, but it was nearly as costly to make the vast improvements necessary to the rim brake system, including mounts! AHHHH! AND,... motor was equipped for disk,... why not? Were the BB5s my best choice? Let's jus say they've been an acceptable choice given the parameters of use I intended.
MadRhino said:
No matter how many brakes you tried or fixed. Once you start to measure your braking distance from 60 Mph in various conditions, you know that no mechanical brake can compete with a good hydro brake.
And yet those 18-wheelers on the highway rely on air-assisted MECHANICAL brakes! As do railcars and other heavy equipment.
Differences in braking distance are enormous with different brakes and riders, and the faster the speed the bigger the difference. Don't go believing that your own experience with mechanical brakes does apply at any speed and any conditions. Braking distance is the only valuable argument.
SAFE, CONTROLED BRAKING, is the only valuable argument!!! And the dynamics of speed, weight, balance, tires, road surface, trail surface, prevailing conditions of environment, brake surfaces, equipment, etc., etc.,..... ALL, affect that safe controlled braking!!!! And without which,... you'd likely have NO braking, regardless of cables, rods, hydraulics or pneumatics!
Technology has made hydraulic disks an available option,.... it's also contributed to improved mechanical cable systems and even rim constriction and rim brakes. Better? Once your "locked-up" you're no longer braking,... you're in a skid! Hopefully a controlled skid! And every kid knows that even coaster brakes can put ya in a skid!
