Also keen to hear how you go pedelex
Shorza, what happened to you r last post? disappeared for some reason.
Have got my 11T to 34T DNP Epoch 7 speed freewheel installed now complete with new 7 speed shimano tourney shifter, it rocks. My best with my old freewheel was 13T, at gear position 5 that feels like midrange now. So happy with this upgrade, I can spin easily to 60km/h with my 53T chainwheel on the crank. Cruising at 30km/s is like childsplay, putting down a bit of extra pedal power is more efficient as not spinning so fast, I highly recommend one of these.
Installation for me was easy, no spacer required with my bafang on the cluster screw in side, and simply swapped an existing spacer from one side of the dropouts to the other to account for the extra gear, slotted straight in. Wired up the new shifter and bob's your uncle.
The only problem was the DNP Epoch freewheel came pretty well injected full of grease from the factory, which made it pretty stiff, thought the bearings were too tight from the factory but after running in it's spinning fine now. Squirted a bit of INOX in the bearings to speed up this process. Was silent with all that grease in there, but now after about 40km is ticking like a shimano freewheel, albeit pretty quietly.
Had got worried as had read on the net elsewhere that the DNP epoch can have quality control issues with one being overtight bearings, but I think it's just the way they grease them up. Seems to be pretty solid, they are made in Taiwan, but are reportedly OEM on cheaper bikes in the market. Regardless, has nickel plate, easy shifting aids being shifting ramps and angled teeth as well as shimano index spacing, changes perfectly with my shimano shifter.
