madmaxNZ said:
I use INOX MX3 in my Crystalyte H4080. It is very low viscosity and hasn't eaten anything. I've used it for about a year and do some very extended hill climbs up forestry roads...temp usually sits around 60degC but can climb to my cutoff point of 85-90degC on one steep-extended section. You only need about 100ml - 120ml, so the lower quarter of motor has the windings covered. It will greatly improve cooling. You need a small breather hole: I drilled a small breather hole (2mm) on the freewheel side-cover near the axel. Also a fill hole on the other side (about 8mm) which you can thread and plug with a bolt. I use a syringe to fill. That's it... sure beats drilling heaps of large holes in your side covers to let dirt and water in.
Well thank you! Today was one of my most successful days on two wheels. A tiny $5 mod with huge benefits ...
I can now ride my Stealth Fighter until my battery switches off! That might sound like a case of "so what" to most people. My problem was the stator temp limit always kicked in well before I'd run out of battery power. The solution was to put 100ml of castor oil inside my hub. Just 100ml (all my local chemist had), and I sealed the hub and drilled a 1.5mm breather near the sprocket. I didn't care about the oil viscosity. Was happy that it's a good dielectric liquid and it's totally non-toxic.
I started out taking it easy, ended up going real hard. My usual on/off power usage on dirt trails. Jumping things, some whips, scrubs and some nice power wheelies, making a corner berm out of everything in sight, throwing it into flat sweeper corners with full power, look backs to marvel at my roost, blitzing up 100m segments of rough terrain trying to maintain 25+ km/h, cringing when I smash over large rocks hoping I don't pinch flat (again), or snap the forks. All up I rode for 95 mins. Air temp in the shade was probably around 29C while I was out there. I was physically stuffed, the rear shock was cooked, but my H4065 castor oil cooled hub motor wanted more. Heaps of animals out in the bush because it was 35C earlier in the day. The lizards always seem to pause and admire my army grey Stealth fighter. It felt like a dream.
The DC-1 displayed motor temp only got up to 1/3rd of full. Normally it's up at full temp (whatever deg that is I don't know) after about 30 mins, then soon the alarm would sound and power limiter cut in, and it took hours to cool naturally. Today my controller temp was very low, but that is normal for my bike. I was thinking all this cannot be happening. Waiting for something to cut out. I'd pull over, take off a glove and touch the hub and controller just to be certain. Yes the hub was hot. Too hot to touch for more than a few secs, but the stator must have been shedding more heat. The motor was pulling as strong as usual. As quiet or perhaps quieter than air filled.
Only the tiniest weep of castor oil came out the breather. I would have drilled a 1.0mm hole if I had the size bit.
In my world, with my kind of bike usage, this test was a definitive as it gets.
