speedmd
Possible is to cast it once wound in high temp epoxy with a bit of long glass for structural integrity and some thermal compounds for heat transfer.
Isn't that an expensive and time-consuming way of screwing up the thermal transfer, thus limiting power output?speedmd said:Possible is to cast it once wound in high temp epoxy with a bit of long glass for structural integrity and some thermal compounds for heat transfer.
Miles said:Lots of possible structures.... This is the first one I modelled.
h0tr0d said:Miles said:Lots of possible structures.... This is the first one I modelled.
If those rings are made of metal wont they brake the motor because of the rotor magnets are moving so close?
Also, really awful thermally speaking...
h0tr0d said:If those rings are made of metal wont they brake the motor because of the rotor magnets are moving so close?
What simulation software are you using with Inventor, Kingfish?Kingfish said:Miles, I have come to the point where I must depart from FEMM alone to answer questions as this and have moved onward to Inventor for more advance simulation; I would not have mentioned it at all until you brought it up.
Miles said:I'd say axial flux motor construction is more difficult. With radial, the static forces are integrally balanced and centered. With axial, you have to design a stiff enough structure to ensure a consistent airgap is maintained. If the magnets and core come into contact during assembly or through accident, that's a non-trivial event
major said:The EVO has end windings ..
So, how are you intending to construct the cores for this topology?dotrick said:If you use the topology with one rotor and 2 stators, the axial force are balanced.
