icecube57
I removed the SLA from the trunk bag leaving the ping pack in it and chargers. I removed my water bottle and holder. Got a local fabricator to make a metal tray in the shape of a T with angle iron on the edges to act as a holder so the batteries dont slide out of the tray. One SLA battery it butted up perpendicular to the other battery . The tray fastens down with the two bolts from the water bottle holder. Its pretty sturdy. Has clearance so i can pedal easily without cliping catching or rubbing on anything. Makes handling the bike alot better. One thing about this tray is that even with flex in the suspension... about an inch or so the batteries can slide in the tray when i go over a big dip. But i stiffen up the spring a bit to limit suspension travel. I got some speed results in. The free wheel speed is around 65-70mph fully charged pack. 32-35mph level and i got it up to 43mph down hill. thats with a 280lb rider 38lb bike 45lb of batteries and 10lb brushed hub motor. My speedo could be off but im sure its set up correctly cause i do 15-20mph pedaling alone confirmed with car driving beside when i tested my speedo. still no torque arms. i got a torque rench and check how much torque i got on the bolts. Well over 100lbs maxed out the wrench I got a person that can make me some to attach to pre existing holes on the s-30 forks. Just all about getting the lazy sob to do it. Money doesnt tickle everyones fancy apparently.
