Should probably start a separate thread for this... don't like thread hijacking. :|
I do exactly 15mi round trip everyday and 90% of the power usage is in the morning uphill and then the batts sit all day with about 2ah left, which is plenty to get me home downhill. No problems so far. Chargers are cheap on Amazon.com (like $20 a pop) so getting more wouldn't be too bad.
You should do a member search for posts by lazarus, maytag, jondoh, mlrosier etc. And also search "Milwaukee" and "emoli" and read, read, read. It's all there. They all have detailed information on how to build a Milwaukee setup. Ditto DeWalt. I guess the online prices just went up quite a bit on the Milwaukee packs. Word it out. :?
My 6 pack of Milwaukees all mounted up and ready to ride is exactly 15.4lbs.
Yup. My personal Milwaukee build is here -> http://endless-sphere.com/forums/viewtopic.php?f=6&t=4716
The default Milwaukee chargers with take care of balancing for you... unless you rip out and re-purpose the cells etc. Then you're on your own.
cnb said:if you go on long distance rides, do you take chargers with you?
cnb said:could you describe your battery configuration n charger name or specs? Myself I'm interested in building either Milwaukee or dewalt 72v 8-9ah. Or could even go 56v, which a standard clyte 48v could handle. is there certain threads or posts that describe on building these packs from start to finish?
cnb said:how heavy are both your batts n chargers? Is this around 10-12lb range?
cnb said:Is your battery pack connected through anderson connectors on your clyte controller?
cnb said:What about having to balance cells? What's this continual process like?
