Doctorbass
steveo said:Hey Doc,
Will your PCB board fit in new gen x5 motor with all the relays and wiring?
I am deciding to sell my x5303 if i can not use dual winding x5303 - x5306 ... it all depends if your pcb will fit... I will keep motor then to experiment
please let me know !
thanks
-steveo
Steveo, I still dont have dissassembled the new gen X5, but i can say that the PCB and relay are very narrow!! I would say that the PCB solder side is max 8mm thick with the wiring included.
For the other side, the relay top just exceed a little bit from the aluminum frame.. maybe like 5mm max. Si i would say that the total added thickness to the 6 brace frame is around 13mm total.
i'll post pics soon.
UPDATE 28 july 2010
The motor is 100% finished!!!, The temp sensor, hal sensor and relay coil all fit perfectly in that 9 conductor flat PARLEX ribbond cable.
Also the Turnigy 10AWG silicone wire fit perfectly in the axel as well.
The wheel is assembled on the bike and now i'm fitting the 18 fets controller..
The welded aluminum lipo battery box is done too. I must find a way to fit it on the frame now.
The bike look very well with those 24 x 3.0 wide bite tires!!
Doc
More update to come!!!
