Eastwood said:
amberwolf said:
For water resistance, fill the entire housing before plugging together with dielectric grease.
Good to know :thumb: thanks!
And for the backside of the PP180s probably would fill it with black silicone.
If you do this, you may defeat the required "floating" contact part of the design, and interfere with the ability for the contacts to mate flat to each other, increasing the resistance of the contact.
That's why I suggested the dielectric grease, because it remains a gel the contact can displace and does not interfere with the design, and it fills all of the housing so water can't intrude, doing the same job the silicone does. (but without the problem silicone has of attracting water, and the problem of some types of silicone of being acidic and corroding the metal it touches).
YOu can get softer silicones (like DragonSkin or EcoFlex platsil from Reynolds Advanced Materials) that are very very soft and flexible that won't interfere as badly (and soften them even more with up to 10% silicone oil added to it during mixing), but the generic silicone in caulk guns from home improvment stores and the like is going to be a lot harder.
If you're set on the black silicone, don't put it inside the housing at all, just make a hollow cone of it around the wire outside the housing, with the wide cone edge touching/bonded to the edge of the housing. It'd still seal the area but it will be flexible enough to allow the contact / housing to work as intended.
I was also thinking could probably make a thin rubber gasket that fits between the male and female connector, sand down some of the plastic material to allow for the space for a rubber gasket. (or just wrap some gorilla tape around it :lol:
If it's filled with dielectric grease, it doesn't need another seal unless it gets so hot that it melts the grease (even then, everything is still coated with it, keeping water off). For the stuff they sell at Checker for battery terminals, that takes at least 130-140F, the temperature of the air inches from the road surface at breezeless intersections in the midday summer sun, sitting there on my bike (or trike) waiting for the light to change and the cars to move.
What are the options for waterproof connectors for the phase wires? I’ve tried looking but I can’t find anything that can handle the current.
do you think those PP180s are sufficient for that much current? I use the phase current often because of off-road use/enduro riding, Lots of stop and go.
With 550 phase amps, sustained, you'd want to use the Anderson SB350 series that is designed for 500A.
They do make a 3-contact version of some housings, but not this one, so you would need two housings on controller side and two on motor side. The housings will each be about the size of the palm of a hand 70mm x 107mm (2.75" x 4.25"), to hold wo contacts in one, and one contact in the other. Length of the connected pairs of housings will be about 183mm (7.2")
Looks like they only make the high-force contacts for this one. Each contact is about 20mm (3/4") wide, and about 78mm (3") long, roughly finger-sized. Contacts are available for 1/0g up to "350mcm", or 185 sq mm.
https://www.andersonpower.com/content/dam/app/ecommerce/product-pdfs/SB350/ds-sb350.pdf
SB 350
Up to 350 mcm (185mm2) Wires
Allows UL rated currents up to 500 amps
Chemical resistant housing option
Extends temperature range down to -40°C, while offering enhanced UV and chemical resistance
Same housings used for wire and busbar contacts
Enables color-coded mechanically keyed wire to busbar connections
YOu could try the smaller ones, as long as your currents aren't sustained at 550A and stay closer to the ratings of the smaller ones; I'm using hte SB50s (rated up to 120A) for up to a couple hundred peak amps a few seconds max but my setup only sustains about 60-80A max, so I don't know how they would perform at higher than rated levels.
The SB175 is good for 10g to 1/0g wire, up to 280A, maybe a bit more than 2/3 the size of the sb350, and it comes in a 3-contact housing so you only need one pair of housings. Would be a lot smaller in total.
