Rix
100 TW
Offroader said:Rix, what do you think about the air shocks? Like I could get a cane creek double barrel in coil or air.
Supposedly the high end air shocks are pretty good and came a long way. They may allow me to adjust the tension exactly how I want it.
I wonder if air would be better or worse dealing with our heavy rear. I wonder if it would be worth buying a used one on ebay to try it out and if it sucks just resell it with a small loss.
Wtih your weight of 135#, you may get away with it. No way will it work for me. The fox Float X was barely good enough on my specialized enduro which weighed 31 pounds. No way on an Ebike. If you go that route, let us know whay you think. I think you would better benefit from the Crane Creek Double Barrel myself. Raptor provides guidelines for spring rates based on rider body weights, how close do you think they are they with hitting that mark?
