Stielz
Ok so I sketched things out in solidworks and realised the rim mounted sprocket will be quite difficult. The sprocket diameter isn't going to be as close to the rim diameter as I thought.
So instead it will be a hub mounted sprocket, just need to find a candidate for a hub that has a surface that I can drill through and bolt the sprocket on. Something along the lines of this photo
The internally geared hubs seem to lend themselves to this sort of design so that's where I'm focusing my search now. Open to suggestions and examples of this being done. Has to have a disk brake mount and preferably a good solid axle.
NuVinci CVT hubs look good just a bit heavy at 2.45kg for the n360 or 3.85kg for the n171. Or perhaps that much additional unsprung weight wont make too difference to the handling..?
