Offroader said:Hi Rodney, just noticed your build thread and read through it.
Just wondering, why don't you put the controller under the bike and use the controller cover. First, the bike looks much better with the cover on in my opinion and you will also have plenty of air flow on the controller.
Rodney64 said:Offroader said:Hi Rodney, just noticed your build thread and read through it.
Offroader, I may as I have a max-e on the way. Actually inside the controller has reasonable heat sink. May put the mini on my phasor and cro on my Raptor. Im 5.9 and the 17 inch MC rims will suit me better as the bikes a bit tall. Currently running 26 inch rims on my raptor and its too tall. I like to touch the ground.
That seems excessive Rod, over 50whr/km! Were you in start stop traffic with lots of WOT bursts off the line or long hills? Even hooning around with mine running at 12kw I dont think I ever saw figures that high. Though I wasnt running fat moto tyres.Rodney64 said:Rode to work today and used 1100 watt hours over 21k. But i averaged 41k per hour
Mind the time zone Rix Rod would have only just arrived at work not long ago so you wont know for a good few hours
Hyena said:Mind the time zone Rix :wink: Rod would have only just arrived at work not long ago so you wont know for a good few hours.
If you keep the speed down to around 30km/hr and the consumption down to a more reasonable and totally doable 25whr/km you should make it home without having to work up a sweat.
What rating circuit breaker are you using ? I take it it's a standard 12v automotive type from the look of it ?
I hope you don't leave the bike too long anywhere with that cable lock either. I'm guilty of using something similar but I wouldn't leave it out of my sight for long - they're easily snipped through by would-be thieves, especially if you regularly leave the bike somewhere and they have time to case the joint.
What calculations are they Rod ?Rodney64 said:Getting ready to ride home. According to my calculations I still have 63% of my battery remaining.
Hyena said:What calculations are they Rod ?Rodney64 said:Getting ready to ride home. According to my calculations I still have 63% of my battery remaining.
As discussed last night in PM I wouldn't bank on more than 1800whr from the pack, so it's actually more like 63% USED than remaining.
If you want to run it right down to see the maximum whr I'd highly recommend taking it easy getting home and then doing laps around the neighborhood, otherwise you'll end up feeling like you're pedaling those pallets of bricks pictured behind your bike
Rodney64 said:
Rix said:Rodney64 said:
Rod, very impressive figures there. That HEB battery is the shiznit! I am curious what the total usable wh are in warm weather above 80F
