"Spot Welding Copper Strips to 18650 Battery Cells"
viewtopic.php?f=14&t=84680
It is the place where the copper/nickel sandwich method was first reported, and enough interest has been shown that some members have asked that this method be given it's own thread. In short...copper foil is inexpensive and readily available as a bus material, but it is notoriously difficult to weld directly to the ends of 18650 cells (currently requires an expensive leaser-welder).
If you overlay nickel on top of the copper, any one of the common "pocket welders" (kWeld/Malectrics...kWeld is more expensive, but is capable of higher currents) will be able to weld this combination onto the cells. The nickel only facilitates the welding, so it is not a conductor in this configuration, since current will follow the path of least resistance, which is obviously the copper (copper is four times more conductive than nickel). The common and affordable 0.15mm thick nickel has proven to be adequate, and the nickel-plated steel ribbon will also work quite well.
The parallel connections can be just about any material that is conductive, since the current is quite small for all cells (less than 1A under all conditions). Nickel, and nickel-plated steel ribbon will work quite well for paralleling. They act as a resistor to slow cell equalization. However, the series connections handle the current of the pack, so using copper there is the best material.
COPPER FOIL
one-mil is 0.001-inch
0.10mm___4-mil__38 ga (crumples like paper)
0.15mm___6-mil__34 ga
0.20mm___8-mil__32 ga
0.25mm__10-mil__30 ga
Pic courtesy of ES member "kdog"
Resistance of materials in Ohms
0.7 x10^-6 Ω.cm COPPER
2.6 x10^-6 Ω.cm ALUMINUM
6.0 x10^-6 Ω.cm ZINC
6.9 x10^-6 Ω.cm NICKEL
9.7 x10^-6 Ω.cm IRON (STEEL)
Conductivity in IACS
100 Copper
61 Aluminum
27 Zinc
22 Nickel
5 Iron-Steel
