Sticky thread index for "Battery Technology"
Status
Not open for further replies.
Ft Riley, NE Kansas
The current order to this thread is:
Miscellaneous
Some ES battery pack History
DIY Pack Building
__Spot Welding
__Resistance Soldering
__No Solder / No Weld
BMS
Controllers
Chargers
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Miscellaneous
"Salvaged EV cells index, Leaf, Volt, Tesla, etc"
https://endless-sphere.com/forums/viewtopic.php?f=14&t=89680
"Connectors"
https://endless-sphere.com/forums/viewtopic.php?f=16&t=2767
"VOC sensor for detecting electrolyte leakage... before it's too late!" (Jonescg)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=96838
ES member Jonescg speaking at the AEVA in Australia, current status of cell chemistry, construction, and design
https://www.youtube.com/watch?v=JNnSW3FtK_o&feature=youtu.be
"LiPo fires and LiPo safety issues, Thread index" (Amberwolf, spinningmagnets, one page)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=69721
"What's the best treatment for KFF?" (2 pages, PICs)
https://endless-sphere.com/forums/viewtopic.php?f=1&t=46713&start=25
"Best Volt meter" (Teklektik, 2 pages)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=66127#p995111
"Headway Pack Builders thread" (frodus, 18 pages)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=12320
"Show Us Your Homemade Battery Housing" (jimw1960, 18 pages) [cross-post from E-bike, general]
https://endless-sphere.com/forums/viewtopic.php?f=3&t=12847
"Index of factory E-bike battery pack tear-downs/pics" (spinningmagnets, one page)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=70581
"Potting Batteries, Thoughts and Experiments" (justin_le, 3 pages)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=71125
DIY battery pack, 25R's from 2014 inside dolphin case (good pics)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=59929
Some ES battery pack history
"Samsung INR18650-20R .. yes these cells can punch, new 24R", Feb 2013
https://endless-sphere.com/forums/viewtopic.php?f=14&t=48074
"Building battery from MAKITA Konion PACK" (doctor bass harvesting Konion cells from makita tool packs), 2011
https://endless-sphere.com/forums/viewtopic.php?f=14&t=28285
"The care and feeding of a123-based packs...", GGoodrum, 2007
https://endless-sphere.com/forums/viewtopic.php?f=14&t=2498
"Bosch 36V fatpacks opened up", John in CR, Nov 2008
https://endless-sphere.com/forums/viewtopic.php?f=14&t=7569
DIY battery pack building threads
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Spot Welding:
"Copper/nickel sandwich" buses for series connections
https://endless-sphere.com/forums/viewtopic.php?f=14&t=108006
"18650 spot welding -how to- ULTIMATE REPOSITORY" (Nobuo, 30+ pages)
https://endless-sphere.com/forums/viewtopic.php?t=68005
"One handed DIY electrode holders" (Fechter)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=89950#p1336769
"18650 spot welding -how to- ULTIMATE REPOSITORY" (Nobuo, 22 pages)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=68005
"Homemade Battery Packs" (DrkAngel, 46 pages) [lots of laptop cell information]
https://endless-sphere.com/forums/viewtopic.php?f=14&t=26383
"DIY spot-welder, FET-switched, processor-timed adj. pulse"
(the original thread about Riba's design, upgraded mostly by Okashira, 24 pgs)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=81400
"DIY Arduino-timed spot-welder, FET switched, adj pulse"
Close to Riba's original design. Some consider this a much longer-lasting design before failure, at a small additional cost. Main theme by flangfrog)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=83411
"Low cost DIY battery spot welder" (K-WELD, tatus1969)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=89039
"BOSS LEVEL CUSTOM SPOT WELDER" (rojitor)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=89076
"Spot Welding Copper Strips to 18650 Battery Cells"
https://endless-sphere.com/forums/viewtopic.php?f=14&t=84680
"Common pack design mistakes, how to avoid?"
https://endless-sphere.com/forums/viewtopic.php?f=14&t=84412
"DIY spot-welder, transformers from microwave ovens?"
https://endless-sphere.com/forums/viewtopic.php?f=14&t=85023
"DIY plating of copper with nickel"
https://endless-sphere.com/forums/viewtopic.php?f=14&t=85310
"Fuse-wire for individual cells, DIY Tesla style"
https://endless-sphere.com/forums/viewtopic.php?f=14&t=88039
"Resistance Soldering Bus Strips to 18650 Cells"
https://endless-sphere.com/forums/viewtopic.php?f=14&t=88965
No Solder / No Weld
"Another No Solder/Weld 18650 Build" (snath, 6 pages [plus more links to other no-solder/no-weld builds])
https://endless-sphere.com/forums/viewtopic.php?f=14&t=57810
"Magnets holding copper bus onto cell, no-weld no-solder"
https://endless-sphere.com/forums/viewtopic.php?f=14&t=104405
"Conductivity improving grease project"
https://endless-sphere.com/forums/viewtopic.php?t=61542
"18650 battery Kit development and discussion" (agniusm, Another no-solder loose-cell box, 7 pages)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=63190&start=125#p1238901
"Conductivity improving grease project" (liveforphysics, 5 pages)
https://endless-sphere.com/forums/viewtopic.php?f=14&t=61542
"Modular Rebuildable Repairable 18650 battery." (shawname "Battery Blocks", using magnets to make connection at cell-tips, instead of spot-welding)
https://endless-sphere.com/forums/viewtopic.php?f=31&t=76205
"DIY assembly kit for 18650 without spot welding/Soldering" (Vruzend kit)
https://endless-sphere.com/forums/viewtopic.php?f=31&t=87434
"yet another solderless DIY battery pack via NIB's" [also using button magnets to hold busses onto cell ends]
https://endless-sphere.com/forums/viewtopic.php?f=14&t=60517#p917007
"Electric Motorcycle (50cc Equivalant)" [19P modules for 14S]
https://endless-sphere.com/forums/viewtopic.php?f=10&t=85758
Status
