DrkAngel
1 GW
Everyone likes more speed!
Well ... most everyone.
What most don't realize is the cost of more speed.
Pulled from the ebikes.ca simulator, I noted the various ranges supplied at different speeds.
Generic Mountain bike - motor only.
665w peak output motor w/48V 10ah battery = similar to a 24V 450w peak output eZip motor - pushed to 36V 675w peak output motor.
Anyway
10mph = 46 miles range - 10.4wh/mile
15mph = 30 miles range - 16wh/mile
20mph = 20 miles range - 24wh/mile
25mph = 13 miles rang - 37wh/mile
30mph = 8 miles range - 60wh/mile
If you travel the same long route on a regular basis ... make a friend along the way.
Stop in for a quicky ... recharge.
eBike forums, clubs or registry?
Help set up a recharge network.
Metricilated 'er up fer ya ...
48V 10ah Lithium battery = 480wh
10mph = 46 miles range ........ 16kph = 74 Kilometer range - 6.5wh/km
15mph = 30 miles range ........ 24kph = 48 Kilometer range - 10wh/km
20mph = 20 miles range ........ 32kph = 32 Kilometer range - 15wh/km
25mph = 13 miles range ........ 40kph = 21 Kilometer range - 23wh/km
30mph = 8 miles range ........ 48kph = <13 Kilometer range - 37wh/km
Remember ...
It's not just, how far you go ...
It's also, how go you far!
Most are shocked at the affect wind resistance plays.
Wind resistance is the major factor, but road load, tires, drive train etc. also contribute.
Makes me reconsider a lot!
Do I need 30mph capability? Nice to have it but ... don't need to use it! - OK! - Still a go.
Road Style bike with high pressure tires and crouched position? - Working on one!
Motor only, crouched behind an Aerodynamic fairing? Sounds almost essential - for sustained 30mph! - Battery pack mounted between bars and fork is a partial fairing. I'm sure I could easily enhance that!
Fortunately, I tend to cruise at 15mph, commute at 20mph with only very limited bursts nearing 30mph.
I'm even considering not upgrading (choke) my latest eZip Trailz LS.
(I use 3 eBikes + latest eZip, + building a road version and an eTrike ... also.)
OEM configuration is limited to 15mph in TAG (Twist And Go) mode and ~10mph in PAS (Pedal Assist System) mode.
Well, not upgrading, till after I run a range trial with my prototype 22.2V 40Ah pack.
I will add high pressure 1.75" tires for less rolling resistance and comfort seat and suspension post ... <15mph range trial might mean 5+ hours in the saddle!
Anyway
Remember ...
