Choudhary
- Joined
- Sep 11, 2016
- Messages
- 33
Namaste. I have been working on my ebike for a couple of months. While researching, i came across recumbents & was quite fascinated by their design. So i ended up making a semi recumbent bike, which actually is quite comfortable.
https://www.youtube.com/watch?v=bTP2SpNtwJg
I got the motor from China - MXUS FX07. It is a geared motor & they call it a 200 watt motor.
I got a front wheel motor because there were some issues in the open size of rear wheel.
As of now, I am using 24v 14ah VRLA battery.
The performance is good. Some things to note are
1. The top speed is around 30kmph. I like it.
2. The acceleration is slow. The motor people say this is because of 24v & will get better with 36v or 48v setup.
3. I have not tested the full range, but with my rides till now, I assume it is between 30-35km on only throttle.
4. The bike slows down a lot on inclines (flyovers) which is annoying.
5. The controller is 7amp - 14amp. The weight of motor is 2.75kg.
I am quite happy with how this bike is running. A lot of people have ridden the bike, and even though it is quite unfinished, they were were very happy with it. So now I am thinking of setting up a shop for bikes like these. And wanted to get some insights.
1. if i use the motor in rear wheel, will the climbing capacity increase? I thing, a smaller wheel should be easier to move with the same torque, hence front wheel gives better climbing. The rear wheel is 24" & front is 20".
2. what brands should i explore for the motors. this is an economical bike (this bike cost me ~280usd. this was the first one. & i am pretty sure the next one would be less than ~200 usd). so i am looking for low budget motors. after reading good reviews about them here & on other forums, I talked to mxus, cute (for Q85, Q100), magic pie, bafang 8fun. mxus gave this motor + controller for $75. i don't remember others prices but they were slightly higher. magic pie was much expensive. it would be nice to know a little about motors & motor manufacturers. I am happy with the way MXUS people have been dealing but is there a better product in the same price range? Also, geared vs non geared?
PS - I used a 24v setup on this bike as I will be adding a solar panel on this bike as canopy. I could have used multiple panels but they were making big cost issues so I decided to go ahead with 24v. My next bikes will be 36v or 48v
I used VRLA batteries for testing the bike. Will be using Li-ion in the next setup.
