eagercyclist
- Joined
- Mar 30, 2021
- Messages
- 11
I ran into an odd issue earlier today. Changed some basic parameters, appeared to write ok, on reading back it had changed several fields to completely different values. Culprit field was Assist 8 Current set to 17%; setting to 16% everything worked fine. Repeated over many attempts.
When set to 16, Assist 7 Speed would change itself to 36% and Assist 9 Speed would change itself to 56%. Additionally, Speed Meter Type would change to either Internal or to By Motor Phase and Speed Meter Signals to 36.
Here are the settings to try to write:
Would be interested to see if anyone can replicate it and if anyone has an explanation!
In case it's also relevant:
