1000km on the Rocky Mountain X503
Lowell   1 MW
Post by Lowell » Apr 21 2007 3:00am
Got home from work today and reset the DrainBrain. 1003km, 39 cycles and 410 amp hours 8)
For my 68km round trip commute, average speeds have ranged from 51 to 56km/h, max speed 90.7km/h, and Wh/km between 31-40.
Reid Welch   10 MW
Post by Reid Welch » Apr 21 2007 4:06am
Impressed! Wow, I most marvel at that economy at such very high speeds.
You = 8)
BiGH   100 kW
Post by BiGH » Apr 21 2007 5:00am
omg thats nuts. You're getting a 68km range!!!! am i reading that right!!
Are you running 84v?
What config is the battery pack!!!
and what mods did you do to the controller!?
VERY impressed over here!
Lowell   1 MW
Post by Lowell » Apr 21 2007 12:13pm
BiGH wrote:omg thats nuts. You're getting a 68km range!!!! am i reading that right!!
I top off the packs at work. 68km would be possible, but at a much reduced speed. Normal Ah draw over 34km is 10-15 Ah depending on speed and how many SUVs I can find to draft. Get behind a cube van and it's like a free tow. :lol:
The battery packs are a total of 76 2D Nexcell 18Ah NiMH, split into three and custom shaped to fit the frame. Controller is an off the shelf 72v Crystalyte, but with IRFB4110 MOSFETs and extra copper.
BiGH   100 kW
Post by BiGH » Apr 21 2007 9:45pm
Lowell wrote: I top off the packs at work. 68km would be possible, but at a much reduced speed. Normal Ah draw over 34km is 10-15 Ah depending on speed and how many SUVs I can find to draft. Get behind a cube van and it's like a free tow. :lol:
mmm very nice :) i'm still impressed.
really makes me more indecisive as to what route i should go for the bike i want to build - 5303 or puma... mmmm your battery capacity is a lot larger than i was planning on (2x 36v texas electric lipo packs)
thanks for the information on ur bike - i'm starting to lean towards the 5303 now for the extra speed! (i can ride at 38kph on the flat anways on my road bike with its new gearing and want an ebike that will blow my socks off so to say)
Lowell   1 MW
Post by Lowell » Apr 21 2007 10:11pm
What I'd like to do sometime is an '04 wind, 20" wheel and 132V. Upgrade to 150V MOSFETs of course, and juice it up with lithium power. This should give around 65mph on a normal bike, along with 155 lbs of thrust off the line. More importantly, 50lbs thrust at 50mph 8)
Mounted on a long wheelbase full suspension frame it would be the ultimate commuter bike.
fechter   100 GW
Post by fechter » Apr 22 2007 12:03am
If you go to 150 volt FETs and run 132v, the current in the FETs might be pretty darn high at partial throttle. Most of the 150v rated FETs don't have the best on resistance or current capacity.
Which ones were you thinking of using?
At 150v, it's getting into IGBT territory. I have seen some nice beefy IGBT modules on eBay. Most of them are 600v. I think you could drive the gates on them with the same drivers.
Lowell   1 MW
Post by Lowell » Apr 22 2007 12:10am
I was looking at the ones from the 150V controller thread. I do agree that IGBTs would be the better choice though.
D-Man   1 MW
Post by D-Man » Apr 22 2007 11:02am
How hot are the nimh batteries getting on this ride of yours? How much more amps can they take before meltdown?
Lowell   1 MW
Post by Lowell » Apr 22 2007 11:35am
D-Man wrote:How hot are the nimh batteries getting on this ride of yours? How much more amps can they take before meltdown?
The packs are 3C rated, which is 56 amps. Packs get a bit warm under hard running but nothing I'm concerned about. I'm not sure what temp the Nexcell chargers cut out at, but the packs rarely go over the 'no charge' temp.
Before I added copper to all the cell tabs, all three packs would go over temp on a long ride.
EbikeMaui   1 kW
Post by EbikeMaui » Apr 22 2007 6:11pm
More speed at less efficiency... or less efficiency at a lower speed without pedaling seem to be the only options with a single speed hub motor. Going back to the basic proven formula.. 1 ah = at least 2 -3 miles at 20 mph using up to 100lbs of batteries ANYWHERE WITHOUT pedaling at 18 - 20 mph on round trips.With lithiums the range and speed gets better per ah. unless you go faster than a 20 mph average, round trip.Above 20 mph average speeds you can expect the figures to get worse fast!
Efficiency and longevity Rules!
http://video.google.com/videosearch?q=ecyclemaui
Lowell   1 MW
Post by Lowell » Apr 22 2007 9:07pm
You must have quoted the wrong post.
EbikeMaui   1 kW
Post by EbikeMaui » Apr 23 2007 3:01am
Oh well. :roll:
Toorbough ULL-Zeveigh   10 MW
Post by Toorbough ULL-Zeveigh » Apr 23 2007 3:47am
EbikeMaui wrote:
Lowell wrote:
EbikeMaui wrote:
Lowell wrote: The packs are 3C rated, which is 56 amps. Packs get a bit warm under hard running but nothing I'm concerned about. I'm not sure what temp the Nexcell chargers cut out at, but the packs rarely go over the 'no charge' temp.
Oh well. :roll:
Isn't there a tiny part of you that just wants the quotes to go on & on...
:P
It's 30-Love. Lowell, I believe you have the serve.
Kick down the barricades Listen what the kids say.
From time to time people change their minds But the Frock is here to stay.
I've seen it all from the bottom to the top Everywhere I go the kids wanna Frock.
Around the world or around the block Everywhere I go the kids wanna Frock.
Lowell   1 MW
Post by Lowell » Apr 23 2007 3:38pm
For the metrically challenged, 51-56km/h = 31.7-34.8mph. For an overall average speed through the city, that's very good, and about equal to driving a car. If your time is worth nothing, by all means go slow and save amp hours. Since I'm paid by the hour, if I were to travel at 20mph, I'd lose $40-50 in billing per day.
