DAND214
10 MW
Zgal48 said:1boris said:The seller told me the motor is silent is that correct?
Yes, it is silent.
The motor alone or the whole motor/gearbox?
Silent, no whine of the motor or gears? that would be nice!
Dan
Yes, it is silent.
Grantmac said:Have the people who've received these weighed them? 8kg seems a lot compared to similar drives.
Zgal48:
What amp rating is the controller you used?
1boris said:what is the q factor ? or distance between pedals.Are the distance symetric on both sides?
DAND214 said:Zgal48 said:1boris said:The seller told me the motor is silent is that correct?
Yes, it is silent.
Dan
[/qu
The motor is silent and the gearbox is noisy when pedalling. But when the motor drives the drivetrain, it is silent. I think the gearing inside the gearbox is made up of metal and not a nylon gear. One day I'll open the gearbox to check if what is inside.
Zgal48 said:I'm just using 35 amp controller 72volts.
Zgal48 said:Grantmac said:Have the people who've received these weighed them? 8kg seems a lot compared to similar drives.
Zgal48:
1boris said:you should ask about lcd here:
yalu@wzyalu.com
