Fiido T1 controller shunt mod?
Promille
🔋 Established
Hi,
I am one of them who have got a replacement Fiido T1 beacuse of OG bikes frame had problems with cracks and breaking.
But i was not satisfied with controller in the new one beacuse it cutts out pedal assist at 25kph so i swapt it out for OG one
and in the process i opend the controller and thougt that i would do a quick shunt mod for some more power,
but the controller does not have shunts like i am used to see.
Does anyone know where the shunts a located or how to beef up amps on this controller?
This is a FOC controller, it has a SMD resistor in each phase rail for phase current sensing. It's a Lishui clone propably. Similar controller PCB:
fetch.php
You don't have to mod the shunts, just flash the right firmware ;)
regards
stancecoke
fetch.php
regards
stancecoke
Thanks,
Tell me more about flashing the firmeware?, i think there is a wire for flashing allredy there is one 4pin not connected to anything.
regards
Daniel
@Deuin in the german forum has successfully flashed a very similar controller of a Himiway Cobra:
It was a little tricky as there are small differences in the pin functions compared to the original Lishui hardware, but finally we had a working branch for this kind of controllers.
regards
stancecoke
Universal-BAFANG-Hub-Motor-Controller-36V-350W-14A-48V-350W-14A-48V-500W-18A-Ersatz-DIY.jpg_Q90.jpg_.webp
regards
stancecoke
Wow thanks,
It's all very interesting but its pretty much greek for me that and the fact that i have to use google translate does not make it easier.
I have to start with which type of programing lead to use, could i modify a lead for bafang bbs? i also have a lead for golden motor and cables for grintech devices.
Or maybe i should just buy a lishui controller rated at 30A, would be the easiest way but not as fun.
regards
Daniel
Nice!
I am willing to take that risk, i have two controllers so i can sacrifice one.
regards
Daniel
I found this controller laying around, looks like a lishui clone to?
How did this turn out? I'm considering getting one of these bikes and the first thing I want to do is boost the amperage.
Wow thanks,
regards
Daniel
Will this work in the fiido t1 if you match and splice the plug ends? All will the display plug in? Does anyone have photos of there's installed?
