smart bms settings
m3vuv
Established
horncastle lincs uk
Hi all,i have a battery with a smart bms,it uses the xioaxiang app 2.1.1011 ver
on the paramerters screen there is an option for open or closed balanced,what does that mean and how should it be set?Tia.
what does it relate to then?
It relates to the voltage of the cells.
Set to open if you want the BMS to balance the cells. Set to close if you don’t want the BMS to balance the cells.
can no body list what all the settings of the app are for and what they do? im using xiaoxiang:v2.1.1011,it would be be cool if someone can explaine all the wierd settings,ie what they do.
There should be a ? Beside each of the parameters, click on that for an explanation.
If you've got no clue it might be better to leave the settings be.
I'm pretty sure if you scroll down there is also a English translation. You may need the newer app, I'm sure you saw it in that other thread.
