raylo32
Yup, that should come in the box with the kit.
Doesn't look like it has the shell on the motor side connector, so it wouldn't still be keyed. You could plug in the other end to it in any rotation that lines up the contacts. (unless the contacts are not at 120 degree angles to each other, and are spaced apart differently on one side than another).I never heard of MT60 connectors, but here they are. They appeaar to be keyed. Wonder why that photo makes a note of the the polarity.
I am also waiting for my motor, i have not ordered it with a custom shaft, i was thinking i should get a regular isis bottom bracket. Maybe that will be a better solution? I also have 73mm bottom bracket on my bike.
I am going to replace a cyc x1 stealth. Think its too noisy for normal riding.
I really hope this motor will be good.
I am looking forward too see the first tests of it.
I dont know for sure that it is quiet, after seeing the very few movies that is about it, it seems atleast a good bit more silent than the x1 stealth. So this is what i am most exited to find out about it.How do you know this one is quiet?
Some pictures have only one chain through the whole thing, some have two. Did they get rid of the drive chain?
Grin connectors page has a good description of them, about 2/3 down the page:I never heard of MT60 connectors, but here they are. They appeaar to be keyed. Wonder why that photo makes a note of the the polarity.
Humm.. Now I realize I forgot to think of the consequence of NO combined dual freewheel and chain/wheel -I have received my kit on Friday, does everyone experience the same dragging of drive pinion when rotating forward (like pedalling with no motor engagement) ?:
below are remaining photos of the kit (with superhero pack) :
power connector (attached) and black LCD connector (seems very unusual)
View attachment 337545 View attachment 337547
square tapper BB has tones of washers
View attachment 337551View attachment 337546View attachment 337548View attachment 337549View attachment 337550View attachment 337552View attachment 337553
Mine has a little drag, but not much. I can spin it with 2 fingers without problem.does everyone experience the same dragging of drive pinion when rotating forward (like pedalling with no motor engagement) ?:
You'd always be waiting!I gave up waiting for this lightest bike one
So the drag could be standard for this motorMine has a little drag, but not much. I can spin it with 2 fingers without problem.
I see you received the power connector with kit. Have you also bought their battery?
It is keyed. Anyway I don't understand why they have used the MT60 for the battery, while it is typically used to connect 3 phase brushless motor to esc. Maybe the XT60 panel mount was bigger and harder to place on the pcb? Who knows!Wait! They are using a 3-prong connector for the battery, and it's not properly keyed? Meaning the end user must check the manual not to cause a short? WTF? Why not XT60?
I got my kit and having some trouble with the ISIS BB too (73mm BB here). Figured it out after 2 hours of tries but probably still have to reverse the shaft and reinsert the spacer to make it work. Chainline does not appear to be correct and especially the ISIS spline on the crankset is not good, seems way too tight. The overall quality of the crankset spline/threads, freewheel, isis spindle, etc... looks pretty poor to me. And let's not talk about the steel chainring! They call it lightest and have a steel chain ring?![]()
I forced it hammering nicely on the shaft while it was on the vice. If I put in on the wrong side of the shaft, as it seems, it will be fun to pull it out...Thank you for sharing your experience!
How did you manage to install the spacer to the shaft? It is very small in diameter.
No, mine was too small too. I sanded off excess material and was able to fit it to Bikee spider.I just noticed you have one of those Chinese aluminum chainring from Deckas. I have bought one from "Snail" that does not mount flush on the spider Bikee provided, because it's slightly smaller. Does yours fit perfectly?
I did not tight down the crankset yet and unfortunately I do not have lot of experience with isis axles to judge if it is good. My 2 ebike kits was from Bafang, BBS02 and BBSHD, and they have square cranksets.Did you noticed fit problems with the crankset on the isis splined shaft? Do they go through all the spline and bottom out correctly? Mine are so hard to tight down and when I had to pull them out with the puller I almost risked stripping the threads. It has been 10 years that I have messed with isis stuff, but I don't remember it being so shitty...
How did they key it without using the housing/shell on the motor side of the connector? I have stared at all the pics showing that I can find in the thread and still don't see it, but I've missed things before.....It is keyed. Anyway I don't understand why they have used the MT60 for the battery, while it is typically used to connect 3 phase brushless motor to esc.
