I think this unit or one very like it was used in another thread here...lemme see...found it
RD6006 0-60 Volt Battery Charger
Unlike most people I primarily purchased the Riden RD6006 power supply to use as a battery charger for Lithium Ion batteries that power my E-Bikes. It is a exspensive solution for that purpose but I have gone through four of the dedicated 58.8 volt chargers in a space of two years. The major...endless-sphere.com
eastwood,
doctorbass tried this
how fast do you need to charge?
Nope, max continuous is 45a. Will be using half the max continuous for most trail/woods riding.Are you running the cells anywhere near their ratings?
received the BMS last week
380a continuous 950a peak.
View attachment 338892I’m not even sure if I can use this display because it needs 24v to 100v to power the unit. How can I use this display without using another step down? Or maybe that’s the only way is another step down. If so, I probably won’t use it. The main reason for even using this BMS display is just to see the voltage, although it’ll be convenient to be able to Monitor the different parallel groups.
Does your BMS have a UART port on the side like this image below
Man I wish It did. Thanks for the help. I appreciate it.Nope, don’t think so.
1) Should the negative and positive discharge wires be equal lengths? With motor phase wires I always make sure they’re the same exact length but with battery discharge wires maybe they could be different lengths?
Depends...what kind of weather does the pack have to endure? How well-sealed is the box?2) should I add vents to the battery box?
I know with electric cars they use vents, primarily dual stage vents to relieve pressure from the cells venting and to prevent thermal runaway. They use ePTFE membranes that allows venting/airflow but stops moisture and dirt from entering.
Just not sure if vents are needed for this battery build?
That’s what I was thinking, since it’s just one continuous series loop it shouldn’t make to much of a difference. My positive discharge wire, which comes off the top of the pack will be shorter because it’s closer to the controller, contactor, etc… and my negative discharge wire comes from the very bottom of the battery, so it will be several inches longer.It shouldn't matter; it's a series loop so the current will be going thru all of the wire regardless of what lenght any part of it is.
Since it does go thru all the wire, the less wire there is, the better, so if making them equal means adding wire to one side, it's slightly better to not do that because leaving the total lenght shorter decreases the resistance by that much (not a lot, but...).
Some people have used goretex vents screwed into holes in their motor casings to allow air exchange without allowing moisture to enter; don't recall how well these worked for them but should be info in the various motor cooling/etc threads.
As long as the vents can't let in anything coming in from the top (let's say you get unexpected drenching rain while on a ride?)My local trails can get really muddy at times so moisture is definitely a concern. If I were to install vents, could put it on the very top of the battery where there would be no direct contact with Water, but yeah still moisture in the air.
The box will be 100% sealed once I’m done with it.
You might need to specify you're looking for vents:Yeah I’ve seen this material mentioned a few times on ES. Every time I Google it, I just found clothing made from the material. I’m not sure where they’re buying the material? I may consider doing this to the motor as well.
How do you like the BMS is it a good buy? i might buy for a 24cell volt module,Thinking about going with this BMS, 380a continuous and 950 peak. Its a new release from ANT BMS, like the fact you can bolt the connectors to the terminals. Since this is 380 continuous, I won’t need to bypass the BMS on the discharge. They also came out with a new 2.4 inch display for the BMS.
Thoughts on ANT BMS?
