There seems to be some issue here with the throttle signal voltage, it could possibly be 'floating' due to lack of a ground reference, i.e. a break in the throttle ground line between throttle and controller. Maybe double check the throttle/motor harness connection - is it pushed fully home, no bent pins etc?Hi there from a french Canadian,
My first post here.
First, special thanks to all for sharing your upgrades, conception and experiences !
I tried to find a resolution here somewhere to my throttle problem but no chance.
I finger cross to have a reply of someone who would help this one too !
The trouble is with a BBSHD controller. It start with a 30H error, and no communication was possible with the commun BBS programing tool. That's why I take the chance to reflash with the new danielnilsson firmware.
The 30H is gone but the motor start wright away at +/- 50rpm !? and at maybe 100rpm on full throttle (Original thumb throttle)
I try a variety of start/end mV combinason without very success.
The best I was able to do is: At 899mV the motor can be stopped IF I release the throttle after 4-5 seconde, but not all the time !
More than 3600mv the motor spin faster but I dont think it reach 150-160rpm.
I try the thottle on another bike with a BBS02 and it work fine.
Maybe I made a mistake in the setting of the BBS-FW Tool ?
Big thank's in advance !![]()
My first post here.
If you take a logical approach to this, the only thing common to all your issues would appear to be the programming cable and the pc you are using for this, I guess it would make sense to try alternatives to these items. The fact that you are having issues with both Penoff's and Daniel's fw (both proven systems) seem to point to this, but I'm aware that this type of problem rarely has a logical conclusion...Sh%t happen twice...
I try another main cable, same problem.
I put another controller, all good,
I try to reprogram it with the commun Bafang prog. tool (Penoff's Hobby Page)
I connect, I read it, I write it but never it say that the flash was done.
Now it have the H30 code.
- The Bafang prog I downloaded have probleme with BBSHD controllers
or
- The portable I use have recents updates that cause the disfunction !?
or
- I have a bad prog cable !?
or
- The new controllers have protections !?
It's starting to be pricy to find the trouble !
Would someone like to sell me one ?
@Bengy22, the throttle work well on another bike. Thanks anyway for your comment![]()
*52v batteryThank you for this you saved my bacon, I flashed biktrix fw onto my bbso2b controller as I have just got a 52v motor & needed to update the voltage etc, it soft-bricked the controller. Just flashed this & it now powers on I haven't looked into adjusting settings yet but thank you so much for this![]()
Hi Mate, are you able to upload your settings, please? They sound exactly like what I am looking for! The way you have set the standard modeseem to comply with UK law.Settings yes, firmware no. There are some copies of the original firmware floating around this forum and others. I haven't felt the need to attempt it yet since flashing this.
Edit: The backed up original settings would not work on this firmware, only when once flashed back to original.
Hello from Spain, someone can help me?
I installed the software for the bbshd v1.5 (IAP15W4K61S4), all settings seem to be working properly, but the max current the display show's is 28.5A when i have set it up to 33A, I tried doing 32A, 31A and 30A but the motor only outputs 28.5A, Im currently running the motor on a 52v 17.5Ah battery and the motor is brand new, i bought it 1 week ago, the display is the 850c.
Thanks in advance.
Thank you geofft for your comment. I take a new prog. cable with a fresh clean laptop. Meanwhile I find and try this source :If you take a logical approach to this, the only thing common to all your issues would appear to be the programming cable and the pc you are using for this, I guess it would make sense to try alternatives to these items. The fact that you are having issues with both Penoff's and Daniel's fw (both proven systems) seem to point to this, but I'm aware that this type of problem rarely has a logical conclusion...
I don't think the newer controllers have any extra 'protection' built in, I had to replace one of my controllers with a new one a short while back and it reprogrammed without any issues. Good luck with this though, we all know how frustrating this type of problem can be...![]()
Thanks for the update, good to hear you are making progress!Thank you geofft for your comment. I take a new prog. cable with a fresh clean laptop. Meanwhile I find and try this source :
Updating Bafang Firmware
Step 1 To perform an update to the Bafang controller firmware you will need a programming cable with a USB connector on one end and a green Higo connector on the other end and a computer.Do not turn power on until instructed! Disconnect the display cable on the bike and plug in the programming...california-ebike.com
Working really great, my 2 controller return to original !
I was assisted by a friend who cleans the computer.
We try again with Daniel's fw but cant find where the prog settled !?
I'm there for now. I will update when I have more time.
Thank's again !
Happy new year for all !
Looks interesting.....these pedal sensors have been around for quite a while now, though I've yet to see any feedback from anyone who has tried them.Could this pedals be used as torq sensors? [Hot Item] Wireless Electronic Pedal Torque Sensor for E-Bike
too expensive. i paid 500€ for my bbshd on pswpower. this new unit costs 600€+import duty+ shipping cost, so probably around 1000€, and then we dont even know if this new motor is customizable in terms of motor parameters and other stuff.I think it doesnt make sense now. The M635 is out!!!! New Torque M435 M635 750w 1000w Bafang Mid Drive Motor Ultra Ebike Conversion Kit With Battery Option - Buy Bafang M635,Bafang Ultra 52 Volt,Bafang M620 Motor Product on Alibaba.com
