offGridDownUnder
🚴♂️ Mega poster
I need to spend time with diagrams and reading to understand the technicals of field weakening beyond the basic idea of advancing the motor phase. This means explanations in math aren't useful, and aren't what I'm asking for. I won't learn much if your answers are phrased this way and you expect me to figure it out - I haven't studied yet, and I want practical advice for this now.
I have a 8T GMAC, a V5 Baserunner, a CA3 Analyst, 48V nominal battery that can provide 40A peak, but probably never has needed to, and a final gear reduction from the motor to the wheel of 60:26 (the 26 is on the motor). I've applied up to 25A of field weakening current in the Baserunner with the trike on a stand, and the indicated top goes up to 50+km/hr. With no field weakening, it is at 27km/hr with that gear reduction.
I have already just read that I should not do this on the stand, but only with a physical load. No smoke has been released, so I'm preparing for tomorrow on the road.
Like the fellow said in the movie: "I'm fuzzy on this whole good/bad business. What's bad?"
As I play with the field weakening current, what do I watch for to decide on what is best? I understand that I will get good torque at low speed, and higher possible rpm at top, but less torque at top. That's fine with me, I'm making a truck.
What's bad? Amps too high? Which amps?
Temperature too high?
I already won't accept not being able to go up steep hills even if only at low speed - I can do this now, and anything that prevents that is 'bad' in my reckoning.
What do I try and what do I watch for to decide what is the optimum setting?
