I have 2 Honda IMA inverters that I was using on a project. I am not using them anymore. One is brand new from Kiwifait and the other one was used in my gocart project a few years ago. I was going to use in my new gocart, but switched over to volt inverter for higher voltage.
One has the reverse broken because I hooked 12V up to the lodgic signal and the other one is brand new. It also has some dented fins on it because I rolled the go cart (no video to prove it happened) They both work just fine (except for the reverse function on the one). Power and regen work on both just fine.
The one with broken reverse is 650, the one that is brand new is 1000.
If interested let me know.
You can see them working in vids about 3 years old on youtube. My youtube name is Eric.Ensley1@gmail.com
Thank you
Eric
Thank you
Eric
