Electrically, that all looks like it will work as intended, to me at least.
You have it draw correctly, Trig - goes to B-, not B+.
What's the difference between the two rockers? Just color?
If you're going with 1kohm precharge, keep in mind that depending on the controller's capacitors, it could take anywhere from 5-20 seconds for a decent precharge. Which is fine.
Also, if you're going with 1kohm, you can basically use "any" 1kohm resistor, not sure you need a $10 item. You already ordered, but here's 10 suitable resistors for $6.
One thing I am still confused on is where the "Trig -" wire from the contactor should go. Is where I have it in the diagram correct, or should I have it spliced into the "B+" wire.
