I remember at least 4.
1st bigger with metal side covers.
2nd the one you see most on this post, crystalite 5403 motor, cycle analyst (v2.3 I think), sides metal/carbon fiber with vboxx.
3rd almost the same but with a new onboard computer replacing cycle analyst and motor is a crystalyte 5580 or 5560 ( I could be wrong on the motor reference), with vboxx.
4rd the one they have now. New design no vboxx.
Just adding to what you said.
1st Generation (2008) bigger frame with metal side covers...and Crystalyte 53xx motor and still had the Vboxx, around 2008. Came with Huge lifepo4 cylindrical Headway cells. Back then you could order one with a 5303, 5304, and 5305.
2nd Generation (2011) the one you see most on this post, crystalite 5403 motor, cycle analyst (v2.25), Frame was smaller, used Lifepo4 pouch cells. 24s 18Ah battery.
3rd Generation, (20014) almost the same but with a new onboard computer (DC1) replacing cycle analyst and motor was still the 5403. Towards the end of this generation, Stealth moved to the UFO 55XX motor. And at the very end of this generation, Stealth started using a new battery which is a 22s 24ah unit until. I do not know which cells are now used in this generation.
4th Generation, (Technically started before Covid, and them some delays with supply chain interruptions around the globe) the one they have now. Stealth acquires the rights to manufacture their own VBoxx. Battery is up to 28AH. They now have the HBoxx. Its like a 6 speed version of the Vboxx spreading the ratios evenly over 618%, electronic shifting, and way more heavy duty, and stronger. Also results in a much stiffer swingarm and frame flex is massively reduced/almost eliminated. Stealth also introduced new heavier and ebike specific disk brakes calipers and rotors front and rear.
5th Generation You will see. All I can say is, this will be my next Stealth Bomber purchase.
Great info, Thank You :).
Can anyone tell me if there is a difference between the Crystalyte H+55xx motor and the UFO motor or are they the same motor?
The H55 and the UFO55 have the same stator armature and magnets. But the sides and spoke flanges are different. The drilling on the H55 is even all the way around the shell, the UFO are series on each side of the hub flange in groups of two. As result, the UFO is much more difficult to lace to rims that have the spoke wholes punched at dedicated angles, where as the H55 is not due to the evenly spaced spoke holes on the flange. Also, the UFO sides and hub flange are shaped like an old school flying saucer, hence the name.
Thank You.
Is there any advantage to the UFO series?
Hey guys I have a stealth p7r and wondering if it's possible to add a 2nd front hub motor to my bike!?!? Would be cool for more torque I guess :)
Now I can point to this sticker, and honestly say, this is how it came from the factory officer. I'm not going to hold my breath though, because it's already been 10 years and no one has ever ask. It's good for laughs on SurRon group rides though.
View attachment 348280View attachment 348281
Morning from West Michigan,
What is your seat height that seat and what is your rear shock length?
I am getting ready to assemble one finally for my youngest D, she is 5-4 now.
Seat height is 32 1/2" and the shock is 11 1/4"
I’m having some issues with my Fighter. I’ve got a E on the display which looks like it’s a low battery symbol. I also get a P next to it when it hit full throttle then a V appears for one second while I’m at full throttle. The battery percentage seems correct as it still has over 53volts.
Not sure what the issue is. Maybe voltage sage and LVC?? It’s set to 45v on the display settings.
You may need to contact Stealth about this. Their codes and DC1 have went through several program iterations since 2014. I am not familiar with the E code and P code when under throttle load. info@stealthelectricbikes.com may be a good starting point. I haven't used this emails since before covid, but if its still a valid email, whoever answers it will be able to assist you with your question.
Thanks for your reply Rix. I’ll send them an email and try to figure out what the issue is. I’m certain it’s battery related.
Do you know what specs a replacement battery needs for the fighter? I know it’s a 14S, I just don’t know what BMS amps output it needs.
Yah, its 14s, so stealth was using pouch cells, that may have since changed. I am not certain because I have been out of the US Stealth "Liaison" scene since the covid shutdown. The BMS they were using were 100 amps units. Again, my information may be dated.
Yah, it’s 14s, so stealth was using pouch cells, that may have since changed. I am not certain because I have been out of the US Stealth "Liaison" scene since the covid shutdown. The BMS they were using were 100 amps units. Again, my information may be dated.
Thanks again Rix
where are people in Oz buying their replacement Fighter batteries from that won’t break the bank?
I wonder if EM3ev.com would be an option...they currently don't offer a specific "Stealth" battery but it might be worth contacting them since the market for a Stealth Battery is going to be increasing for quite some time IMO.
I might be able to help. I offer value for money, not cheap. I'm currently booked out for the next few months at least. Check my website in my signature block for info.
Cheers
  • Like
Reactions: Rix
Will look into it.
