Thank you for this post. My bike is the same model as your's. I was wondering, was it necessary to space out your side covers, and where did you fit the BMS?If I may, I’m already a bit late but I made a battery for this stealth bomber model using 21s 9p with molicel p42a, you get more power and more ah.
Here some photos, used kweld.
View attachment 353044View attachment 353045
Hello, no the battery is the exact size of the frame, almost 12cm. You can see no space is needed between covers and frame.Thank you for this post. My bike is the same model as your's. I was wondering, was it necessary to space out your side covers, and where did you fit the BMS?
If you had used plastic cell spacers instead of staggering and gluing the cells together (to save space) would your DIY battery still fit in the frame space of your bike?Hello, no the battery is the exact size of the frame, almost 12cm. You can see no space is needed between covers and frame. The BMS goes on the top of the battery.
Try to use the outsides of the original pack made from fiberglass to design your battery, I made mine using them as limit and even used them to close and protect the pack. The pack is the exact same width as the original.
If you had used plastic cell spacers instead of staggering and gluing the 140 cells together (to save space) would your DIY battery still fit in your bike frame ?Nice Controller, I have the same on my Futr Beta or Stealth P7 Running 20S7P 105A Mxus 3k, Good Work i built my own battery and whole bike never its still going strong after 5 years.
Sometimes there doesn't seem to be any other option other than staggering the cells and gluing (to save space)) in order to fit your DiY battery pack in the bike frame. With a BMS temperature sensor is there little need to worry about thermal runaway ... correct?
What is the best method to monitor cell pack temperature of a glued staggered cell arrangement in a custom DIY battery pack to hopefully prevent any danger of thermal runaway?
Do you use an internal temp sensor in the middle of your 20s7p battery pack or does the BMS shut-down the battery should the temp of any of the innermost cells gets too hot (thermal run away?).Will(With) plastic holders would not fit the frame.
Have you run any tests to see how long you can run at MCD before innermost cells of your 20s7p reach ... say 110 F, 43 C) ? What do you consider the maximum inner cells temp to throttle down preventing the danger of thermal runaway (fire).
Im still rocking the Ant BMS and have the VBMS app it shows all cells and temp alsoIf you had used plastic cell spacers instead of staggering and gluing the cells together (to save space) would your DIY battery still fit in the frame space of your bike?
Thanks for the info. That's a different store than the one I bought from but the product is exactly the same.O have used Ant BMS 300 amps, they are cheap and good, they will fit on the top of the battery no problem.
Here is the link. 24s double layer version (2,5cm)
https://a.aliexpress.com/_EGkZah9
Have Bluetooth, predischarge, 2amps passive balancer, etc etc
This should work fine with my 80A controller. It's tempting to plan on upgrading, but my bike has been so satisfying to ride since the last upgrade I think I'll leave it alone for once. I'm already expecting somewhat better performance from a less saggy battery.
Looks almost like the original BMS from stealth.This 100A, ANT BMS came today. Love the small size. View attachment 354155This should work fine with my 80A controller. It's tempting to plan on upgrading, but my bike has been so satisfying to ride since the last upgrade I think I'll leave it alone for once. I'm already expecting somewhat better performance from a less saggy battery.
I'm planning to use 0.20 mm copper which I'm waiting on.. The layout will be like this.Looks almost like the original BMS from stealth.
How will you layout the nickel on this battery?
you can even fit 21s9p in your frame, im doing one with this size next week and will be posting the photo here.I'm thinking about something like this as an alternative design. I could fit 20s 8p 40ah in my frame. There seems to be more advantages than disadvantages to this kind of design. A battery made like this running a 80 amp controller is probably not going to ever get very hot. It would have potentially 200 amp discharge capability.View attachment 354658
My opinion, if it's mostly fiberglass base supporting the weight you'll want 1mm or greater, and the thicker you can fit/afford the better. You'll also want a sturdy frame/armature/case, and if that's robust enough you can probably go as slim as .5mm thickness. Pack weight being a critical factor. Others probably have some useful perspective on this too.The plastic holders I'm using don't snap together or connect in any way. They're 5x4. I'm guessing the pack will need to be supported on some kind of base foundation? Can anyone elaborate a little about this. I do have on order a fiberglass board material that battery suppliers sell, but I'm not sure if this is what it's used for.
I just purchased a bomber with no battery. I have 2 older 72v 11ah packs that I have been using to ride it around but I will need to build a new pack. I will probably go with a 20s configuration but I’m still deciding on which cells to buy. Theadore, where did you end up purchasing your cells from?
