Which frame to choose for an Enduro full suspension mountainbike - with Bafang M620??
Hello everyone.
Id like to build a full suspention enduro mountain bike with the M620 motor. Which frame should I choose:
- Needs to be Aluminium
- Needs to fit 27,5 inch wheels with up to 2,8inh width
- Needs to have battery integrated in the frame
Links would be appreceiated
Many thanks !
Michael
AFAICT, the 620 requires a dedicated frame, so you need to investigate which are possibilities (and likely available from "Ali".
Thanks for your replies.
Im not planning on building the battery myself. So it needs to be sort of a package. Or id need to find a batery that fits into the frame. Im aware that the M620 requires a dedicated frame.
Does anyone else have a suggestion ? There must be someone that have done some research or have some experience ,0)
Thanks
The build thread subforum has some builds, but mostly custom. You’re basically looking for a prebuilt ebike, minus the bike stuff, which is a niche, since most folks either buy factory built, or go full DIY, the latter being somewhat more popular on ES.
The problem is that this route in particular limits your choices for the battery and leaves you with limited choices and no opportunity to choose which cells are being used. I would never go a route where battery selection isn’t under my control.
Thanks for your input - much appreciated
