j bjork
Im taking it a little easy with the start welding part. I want to make sure I dont have to change anything, and trying to decide how everything should be held together.
The cell holders are watercut.
Testing bus bars, everything seems fine, but some of the little tabs for the balance wires will be in the way.
There is a lot I havent decided yet, like how I will build the box. Where I should put the discharge connector, what connector to use.
What bms to use.
I would like something integrated in the vesc system, but I dont know what to go for.
There is the trampa bms:
It is 18s, and I dont see anything about running two in series or something like that, but I know I have seen it done.
12A charging?!
2 for each battery wont be cheap.
www.ennoid.me
Ennoid XLITE-V4
There is a 32s version, but it says "beta, GH cable set not available yet"
So, beta probably means trouble, not sure what GH cable set means.
Charging 20A with alu cover, didnt see one available on the site.
That is ok for normal charging, but what if I want to charge fast sometimes?
35mA balancing? Lets hope the batteries wont need balancing then, it would take a while..
Maybe it would be possible to let the charge port control a relay for the charger, then charge trough the discharge connector?
If the bms sense something wrong the relay opens and the charging stops. But it will not sense the current going to the battery.
Wonder what will happen to the state of charge display?
I think there should be some more bms:es that work with vesc?
What bms to use.
VESC Based BMS - Balance charges up to 18s
Trampa Boards : Custom mountainboards, kiteboards and parts.
trampaboards.com
12A charging?!
ENNOID - XLITE-V4
XLITE-V4 is an updated version and almost a direct drop-in replacement for the XLITE, XLITE-V2 & XLITE-V3 Reminder: Monolitic BMS are not recommended for split packs. We recommend using Master-XLITE and slaves for split pack or using the XLITE-12+ with a 24S slave (see wiring diagram for XLITE-12+
Ennoid XLITE-V4
