I am currently running a 7 speed freewheel on my Leaf motor but I usually leave it on the 22T cog so I can pedal if the motor needs a little help on a steep incline.Are there other rear cogs you are using?
Thanks...glad I chose the freewheel version of the LeafThe axle end that passes through the motor's splined freehub is much smaller than the one on the threaded freewheel version. This means not only is the axle weaker and less rigid on that side, but the faces of the axle shoulder that bear on the frame (or on a washer used to protect the frame) are much smaller and more likely to indent the mating parts or to become mushroomed, thereby effectively loosening the axle nut.
One thing that concerns me about the Leaf 1500w motor is that while it is able to run cool and efficient at 2000w (with the appropriate sized wheel) I don't think the average shark battery pack from EM3EV will be cool and efficient if used with such a combination.
For example, Samsung 35E cells are rated at 8 amps max continuous current. Since the largest shark pack from EM3EV holds 70 cells for 14S 5P that puts the pack's maximum continuous current of 40 amps (re: 5 x 8 amps = 40 amps) and yet going 40 mph with the typical bike from this thread will pull more than that thus pushing the BMS into its burst mode of 55 amps maximum.
Even the EM3EV Triangle battery pack at 14S 6P looks inadequate for the average bike build in this thread:
EM3ev 52V (14S6P) Hard-Case Triangle Ebike Battery Pack With Bag | EM3ev
EM3ev 50V (AKA 52V, 14S6P) Small Triangle Ebike Battery Pack, uses top quality official Samsung and LG Chem cells safety features not to be found elsewhere.em3ev.com
So if a person wants to push 40 mph with the chassis commonly found in this thread the battery should likewise be much bigger in order to match the efficiency of the motor. Pushing small batteries to max continuous power draw is hard on battery efficiency as well battery life.
Best to choose a bigger battery in order match discharge efficiency with motor efficiency. What is the point of having a motor with 90% efficiency at speed if the battery is simultaneously poorly efficient. In some cases (e.g. chassis limiting battery size) perhaps it is better to have a motor with less efficiency but with higher torque per amp when using certain small batteries.
Although the Leaf motor will do it without over heating if you run Statorade, there are better choices for a motor if you want to cruise at higher speeds...QS205, Cromotor, and the Crystalyte H55100 would be the motors I would recommend. The Crystalyte has a 55mm stator.
EM3ev is very conservative with their recommendations but if you follow them, your battery will last a looong time...they recommend ~50% of the max capability of the cells for "burst" current.
In my experience, most ebike components can handle 40A and if you stay below that threshold, you'll never have a problem. But as you go over about 40A, everything needs to be resized, replaced or at least evaluated to see if it can handle the amperage.
If you have 35E cells in your battery and you have the EM3ev smart BMS, you can safely pull 8A per "p" string but your battery just won't last nearly as long as it would if you pulled 4A per "p". If you have a 14s5p battery with 35E cells, the run below shows you can only get about 35 mph with 40A assuming you are sitting upright.![]()
New Member Glad I found this place
Hello Endless-Sphere new member here and considering building a fairly high end e bike. I've built a Gas motorized bike before years ago. It was with what's called a shift kit (basically the mid drive version of a gas bike) and a fairly common motorized bicycle motor. Once I worked through the...endless-sphere.com
"That leafbike 1.5kw motor can be pushed to 40mph almost continuously, add ferrofluid and it might sustain 50mph."
Also remember Leaf also sells the 35mm motor as a 2000w when used with a 60v controller.
EDIT: Although neptronix did state the following also ---> New Member Glad I found this place
"40mph needs 2000w to sustain the speed on the leafbike 1.5kw if you are in a tucked position, a few hundred watts more otherwise. it will be at around 85% efficiency at that point. Will tolerate that for about 5-10 miles continuous before overheating if you add no additional cooling tricks ( hubsinks, ferrofluid, or drill holes into it )"
I reckon 5 to 10 miles at 40 mph is pretty good. In the world of ebikes (where the "long range" is much much shorter than in the gasoline world) that would qualify as almost continuously I believe...........
This must have had the Samsung 50E, not the Samsung 50S. Both have 5000 mah capacity per cell but there is a big difference in max continuous discharge with the Samsung 50E at only 9.8 Amps rather than 25 Amps which the Samsung 50S has.Yeah i have a 52v 19.5AH pack of those; 40A aka ~2C is where they start to get saggy. You're really pushing them at 2.5C.
em3ev started selling a pack with it a few months ago.
Molicel P45B is a hell of a cell if you can get your hands on them.
Nope, i have the 50S.
Consider that max continuous amps for any cell is simply a thermal limit ( due to energy waste ) for a single cell at room temperature that's below the threshold of it blowing up or dying.
You want to derate the hell out of those figures because oyu have all your cells crammed together with no outlet for the heat.
That and the horrible voltage sag and capacity loss you get at full blast.
Not to turn this isn't a battery thread but the P50B is already old news, leaked spec's of the upcoming P60B:And I was thinking the 13.5 amps max charge for the Molicel 45B was impressive then comes this:
Holy moly, this is the first time i've seen someone stuff 6ah into a 21700
When did those come out, and are they unobtanium RN?
AMZ technologies had back in 2014 a geared hub motor of 7 lbs that could do 50+ horsepower peak. Used in the world's fastest-accelerating EV, but not for sale to the public.
I’d like to see the M635 build. I don’t see many folks using it yet, so it would be nice to see an example and hear the real world experience. Thanks for checking!For my next bike I’m looking at either a torque sensing Bafang M635 torque sensing BBSHD or a Leaf 1500w.
Well technically they are not out yet. It was leaked in a annual report you can read here published back in March. Estimated completion of R&D in 2024. Those figures should be taken with a grain of salt but I would bet if they are off its not by far considering where I found that photo was published before the 50B figures were out. But the 60 in the same suggests 6ah and the "P" nomination is for their high discharge cells. Probably will be another year or two before mass market release though. P50B's has had samples out since the beginning of the year (at least) and still hasn't hit mass market, most guesses seem to be EOY. Also worth noting is the crazy XA3 cells they are working on. 4ah and 90c discharge and a 40c charge (seems to be a 10s peak though). https://media.taiwancement.com/web_tcc/en/report/annual/2023 Annual.pdfHoly moly, this is the first time i've seen someone stuff 6ah into a 21700
Can anyone advise how expensive and time consuming, complicated to set up the Leaf will end up with
- regen braking
- a controller capable of 4-5kw bursts
- dual battery setup potentially (eg 2 x 48v or 52v batteries run in parallel for double amps of nominal rating l, plus regen on dual batteries if they are paired correctly)
I think there were some other factors I was going to consider but can’t remember now. I’m leaning towards the Leaf for ease and simplicity with drivetrains, but am not sure if efficiency will be all right with a fair bit of serious hill climbing.
The other option to wait for is the Proton mid drive from CYC capable of 3kw+, But it will be expensive and a long wait
Not really. The choices are so random that there is not clear use case, and just a random wish list. You’re welcome to go the twenty questions route. (I didn't suggest any ebike parts. I only expressed my preference to see an M635 build).That has to be the worst reason ever to suggest an ebike part.
