I've got a 3000 watt ebike kit (it's pretty wide & powerful, so I think somebody just put a moped motor on a bicycle wheel) with a really dangerous problem: on extremely rare occasions, it stops responding to the throttle and immediately goes to maximum power. Since this thing literally does 60 mph at full throttle, it's basically a death trap. I'm interested in just how a product could end up with a problem like this though.
The setup: 3000 watt rear hub motor with throttle connected and working properly the vast majority of the time, pedal assist not connected at all, and rated for a maximum of 80 amps continuous draw from the battery, so I'm assuming it spikes to around 5000 or 6000 watts on demand. Sometimes, very rarely, maybe once every week or two with daily use, it -- with no warning whatsoever -- just takes off like a bullet. Completely ignores the throttle and power assist level and instantly maxes out.
The first time it happened I didn't have the brake cutoff connected yet, and I was barely able to slam both front & rear brakes down enough to bring it to a stop. Even motionless it wouldn't disengage no matter what I did. It only powered down once I smelled something that I can only assume was the motor overheating and probably triggering an internal cutoff. There's no indication of anything odd on the display when this happens, either (no error messages).
Now that I've got the brake cutoff connected, that signal does cut the power to the motor instantly no matter what. Putting aside the fact that I have a death wish for using this thing, I'm very interested in just how this behavior could possibly be a simple bug. Can anybody familiar with the internals of a three phase brushless electrical motor weigh in on just how something so dangerous could get past any company without being noticed? I'm assuming it's the controller and totally unrelated to the display, because when it happens, it definitely feels like it's accelerating slightly faster than even full throttle does.
