j bjork
A friend left these bikes at my place:
Both are new, but probably a little test driven. Now with dead batteries.
I have opened them up, the ds with dc motor has a big 14s battery:
The XU has a 18s battery:
At the moment I am trying to decide what to do..
The XU seems to have a sevcon controller, I think they are 48 or 80v.
My guess is 80v then, so it should be no problem running 24s if I could reprogram it.
Like this, but it would be pretty crowded in the box.
But if I build a 18s, I should be able to run the standard bms and everything should work right?
There is a connector that you would normally reach trough a hole in the case, is that needed?
There are also some leds that you can see trough a glass in the case, what are those for?
The interior of the battery would be a bit different on mine so the bms wouldnt fit were it normally were mounted
