I NEED A case is 4x8x35cm inside slides in a 4+ x 9cm hole in the alloy frame
NOTA
100 mW
MIAMI
THE BIKE IS A DEAD UNKNOWN FOLDING 20'' made in CHINA?
250W hmb IN SIDE FRAME BATTERY MOUNT
called a intense design a-1
found 10 year old ads listed as out of stock
would like to buy or build a liFeP cell battery to fit inside the frame 4+ x 9 cm 35 cm long
old battery works when it wants to [cuts out at random] would like to find a case if not a whole battery in my size
hints ?
hints ?
Why don't you put new cells in the old case? You can get better cell quality and capacity that way.
Would like to retain the semi functional battery as a spare
also tryed to press out the existing with finger pressure no movement of the pack
as both ends were removed plastic end caps it is tight in there
case is an al alloy with small fins/ribs on the short sides 4 cm plain/smooth on the 8cm
is that a common sized battery case in china or euro's ?
4x8 cm is not a USA size I can find
I get that, but I think it's backwards. If you can find a generic pack small enough to do the job, it won't be made from top shelf cells. So the amount of total energy in it and your mostly-dead pack put together, will be less than you can stuff into the single case by using high performance cells.
