PLEASE HELP ME BEFORE I SCREW SOMETHING UP??Running an e hub motor without display or hal sensors?
bigsteve75
Monroe, LA 71201
Can I run my 3 phase, 48v/1000w Voila mart,(brushless)rear hub motor, without the hall sensors and the display? Also,I recently purchased an aftermarket,48v/1800w 3 phase(brushless )controller,is that compatible with that specific hub motor?(48v/1000w 3 phase hub motor (brushless).i noticed want to run the. Otir without display or hal sensors,can I run a controller with 800 more watts, without hurting anything?
Can I run my 3 phase, 48v/1000w Voila mart,(brushless)rear hub motor, without the hall sensors and the display? Also,I recently purchased an aftermarket,48v/1800w 3 phase(brushless )controller,is that compatible with that specific hub motor?(48v/1000w 3 phase hub motor (brushless).i want to run the motor and controller without the display or hal sensors,? And if I can run that combination ,can I run the controller with 800 more watts than the motor ,without hurting anything?
It depends on two thing if your drive requires hall sensors it won't work and for your higher wattages drive I guess no hall sensor (good) and if it can be adjusted or if there's a connection marked self learning usually need to plug then the drive depending on many things mai take around 2 or 3 minutes but I already seen one take 6 or 7 min to complete
Are you talking about the hall sensors inside the Voilamart motor? THere would be five thin wires in a 2x3 plug in the motor cable to support therm. They are needed by many controllers to figure out the position of the wheel so they can sync the power pulses, but a sensorless controller can run without them.
If you controller only has the three thick blue, green and yellow wires in the motor cable and no 2x3 white plug, it is sensorless.
