I think yes. "Should," being the key word. It's important to note that Chalo isn't wrong about adding a mechanical issue to be aware of if one decides to use regen in their build. However, if you're aware of the issue, and take proper precautions to alleviate it, then regen can be helpful. It's also important to be aware of how much charging current your battery can take, and whether your preferred amount of regen is more/less than that.So you are saying with proper torque arms it should be fine?
So yeah, I agree with Chalo that regen isn't a one-size-fits-all solution for everybody that can replace mechanical brakes. There was a poster awhile back, can't remember exactly which, that was planning a scooter build with zero mechanical brake function to rely purely on regen braking for stopping. Which is of course a bad idea, what if the controller fails mid ride? He would be unable to brake. And there are plenty of examples of dropouts without torque arms failing and hub motors spinning out, or cheaply-made torque arms being used that get chewed up by steel axles reversing toque during regen.
However, I disagree with his comments about regen being inherently useless and ineffectual. For example:
Motors aren't being retrofitted as brakes. Back-EMF is present in electric motors regardless of whether regen is being used. If the effect is there anyway, and proper precautions are taken to prevent mechanical or battery damage, there's no reason why it can't be used, in addition to mechanical braking. Whether someone wants to deal with the added mechanical issues that come with using regen, and whether it is worth it for their build or not, is going to be different for every person. I think that's what this forum and DIY is all about anyway: making yourself informed about the cost/benefit of your project choices, and acting accordingly.Also, brakes designed as brakes work better as brakes than motors that are retrofitted into service as brakes.
