38% of cars sold in China are now electric, Sinopec says the ICE is doomed
Two systems might mesh elegantly (always a goal for a good engineer), and otherwise some good engineering might mesh them well despite inherent differences (a source of pride for a good engineer).
Good engineering is using one component to do two or three jobs, not using two systems to do one job.
well , down here in Oz, the Toyota Hilux truck is one of the top selling vehicles, and is also now available as a “Mild hybrid”.
Basicly this is just a 48v , 16kW, “Altermotor” system with a 1.4 kWh battery….much like many other 48v systems fitted by GM in the US, and European manufacturers to meet the latest emmissions targets.
In the Hylux (and likely the Tacoma) the system achieves a claimed 10% improvement in fuel use by enabling the use of engine Stop/Start function , and removing the main engine power drain of the ancillaries (AC, power Steering, etc)
The system does not operate in the same way other Toyota hybrids do..(ie the truck cannot be driven on electric power only), but the battery is primarily charged using regen braking.
That may be one idealistic definition, but good engineering can also be defined as any solution that improves the efficiency, performance, simplifies the construction, or reduces costs , of a product.
EG, there is a very good reason why many heavy goods locomotives are diesel powered, but use electric traction motors..
1). It eliminates the need to electrify millions of miles of rail systems if only electric drive was used
2). It eliminated the hugely complex and expensive transmission and drive line that would be required to transfer the huge torque of a large diesel engined train to multiple traction axles. Electric motors on each axle is simpler and cheaper.
So, using 2 systems to do one job solves many problems and reduces costs.
Similar could be said for the use of Combined Cycle Gas Generation plants, where both chemical energy (gas turbine) is used in conjunction with thermal energy ( steam turbine ) , to do the same job .(.power generation), whilst improving efficiency and reducing costs.
Diesel-electric locos are using the electric part as CVT, nothing more. Gas peaker plants are used to close the gap between demand and efficient supply, nothing more.
You are avoiding the point…they could just use a full electric drive, but huge infrastructure costs.
However diesel/ electric, ….two systems for one output =.clever engineering
There is different types of gas plants …CCGT’s employ 2 systems to improve efficiency = clever engineering. !
Nothing to do with EPA, the MPG is only like 1 better, and not sure folks are even seeing that in the real world. They did if for marketing and specifications bragging rights. And yes, they both hybrid and non-hybrid have the 10-speed transmission, which is fantastic. I have a non-hybrid version and it has tons of power... and decent economy for a big ICE vehicle. Basically gets the same MPG as my 2009 Tacoma that I sold when I got this. The hybrid's extra power is totally unnecessary, but I suppose if you had a maximum rated trailer that extra tq from the electric boost would be nice for getting it moving.
As a side story Toyota has recalled over 100,000 of these engines due to premature main bearing failures. They claim that manufacturing debris was left in the blocks and that stuff gets pushed into and caught in the #1 and I believe #3 main bearings on the initial startup. Then over time those bearings can fail catastrophically. Happens to many around 20,000 to 30,000 miles. Mine has 25,000 now. Toyota hired 400 extra folks to build new engines and they are currently shipping to dealers around the country. Mine is scheduled to be replaced in May.
Interestingly, the hybrid versions are not recalled because it is not deemed a safety issue since one with a failed ICE engine can theoretically move itself out of harm's way with the electric motor. Those engnes are still have the regular warranties but there are many unhappy hybrid owners out there. This has been a bit of a shit show for Toyota.
From what I know the Tundra/Tacoma "hybrid" drivetrains are a traditional drivetrain from an ICE version of the vehicle with an electric motor and a battery just bolted on top in a sense. Nothing like the real hybrids. It even still retains the same geared automatic transmission. Perhaps it has something to do with EPA MPG mandates. Perhaps they just made it because marketing said there is a market and developing a bolt on kit costs little. Who knows.
A little clarification on these Toyota hybrids.
the USA Tundra is a 3.5ltr V6 gasoline motor with an integrated 60+ hp electric assist ..
the US Tacoma is a 2.4ltr, 4 cyl gasoline motor with a similar integrated 60 hp electric assist.
the Australian Hilux / Prado is a 2.8 ltr, 4cyl, diesel motor with a 20 hp , 48v “altermotor” assist system.
Toyota do not refer to these 48v systems as “Hybrids” , since the vehicles cannot be driven on electric power alone, and their primary function is to improve fuel consumption.
Here is a photo of one of the new petrol 3.4L twin turbo replacement long block motors for US Tundra. Pretty complicated. Same engine goes into the non-hybrid i-Force and the i-Force Max hybrid.
And what does an BMW I3, an electric car, has to do with hybrids? :unsure:
The BMW !3 is a series hybrid...its "range extender" ICE motor is only connected to the drive train electrically, through the generator and battery, there's no mechanical connection
Your awareness of EV tech is less than you think.
No, …for one they specifically refered to cars….not trucks.
but if you want to compare a Hybrid Tundra, maybe you should consider an “apples to apples” approach and think ,…”is a hybrid Tundra better for the environment than a non hybrid version “ ?
..or 90 hybrid Tundra’s compared to 1 BEV Rivian ?
..."No, …for one they specifically referred to cars….not trucks."...
No they did not. Look again at your little green graphic. It's "vehicles", so the magazine quote you're nitpicking was accurate.
..."and removing the main engine power drain of the ancillaries (AC, power Steering, etc)"...those loads are not "removed", they are shifted to electrical drive, but ultimately still drawing energy from the ICE engine. There may be slight gains in efficiency in doing that, but probably the most advantage comes from better packaging and lower maintenance (no belts)
Just looking that thing makes me disgusted. The Prius' motor is so much cleaner than that.
Nothing beats the electric motor though! ( iMiEV motor)
From NTSB publication... "Investigations of EV fFires"
"Observation #5: Current EV Population"
Tesla
• ~ 350,000
• 17+ fires (0.005%)
Nissan Leaf
• > 300K
• No known battery fires in service
Chevrolet Volt
• > 200 K
• No known primary battery fires in service
BMW i3
• ~ 100 K
• At least 3 fires
Evidently the NTSB does keep some sort of track of EV fires.
Maybe we add one more to Teslas 17+ fires?
We'll see what the investigation uncovers.
As is yours apparently..!
The BMW i3 is a plug in EV, Not a hybrid of any variety !
…the “range extender” was a different model , the “i3 Rex” , and is no longer available .
certainly the energy was originally generated by the ICE, but would have been wasted as heat from the brakes.
…instead the kinetic energy is recovered by the regen system and then used to power the ancilliaies…effectively removing those loads from the main ICE. That , together with the use of an engine stop/start to reduce idling time, is claimed to result in 10% fuel reduction which helps Toyota meet the new carbon emission levels being introduced in 2025.
Also, the point obout less belt maintenance is not relavent as the 48v “altermotor” Is belt driven both to the main ICE , and the ancilliary components.
Oh, I still like ICE motors. Cams, rods, pistons... the interplay and timing of all the parts, now enhanced with modern electronic controls. Good stuff. I also like the electric motors, just in a different way. It is sort of like comparing a Rolex mechanical watch to a Casio digital. For the watch, I'd actually take the Casio, since the extra expense of the Rolex does not buy you better function. For vehicles right now, I'll take the ICE, simply because of the high initial cost and poor convenience/high cost of charging EVs on road trips. But hopefully the charging infrastructure will improve and some of the advanced battery concepts that promise to increase range, reduce costs, and charge faster actually come to fruition in the not too distant future. Once cost and convenience approach parity I will reevaluate.
Nothing you've said changes the fact that a BMW i3 with the range extender option is a series hybrid, what works just like "an ebike with a gasoline driven generator"
Bwaaaahaaahahah! More of your bullshit. The ICE provided all the energy for the ancillaries, that load wasn't "removed". No pure ICE vehicle runs regen, there has to be an electric motor in the drive train to make it possible.
You can try to claim that the regen braking is powering the power steering if you want, but you look stupid trying. Especially since it was mostly the ICE that accelerated the car, giving the regen energy to work with.
All that bullshit, to gain 10% in MPG.
..and nothing you’ve said changes the fact that the “BMW i3“ is a pure EV
If you are talking about the ranger extender model , at least use its correct model name..”BMW i3ReX”
Any EV with a generator in the trunk ( or on a trailer behind ) is a hybrid…acording to you.
What makes you think there isnt an electric motor. ”in the drivetrain” ?
you obviously do not know what a “mild hybrid” or “altermotor” actually is , or does !
V-Active Technology also provides improved performance, with energy stored in the battery used to provide additional powertrain output when accelerating and helping reduce the load on the engine in areas of the rev range with lesser efficiency.
During deceleration, energy is recovered by the motor generator which is fed back into the battery, combining with the engine braking to provide natural deceleration characteristics.
So you agree, all the energy for the ancillaries comes from the ICE in a hybrid?
I jut said there was, in the statement you quoted, and then misread.
"The BMW i3 is an electric car that was manufactured by German marque BMW from 2013 to 2022. The i3 was BMW's first mass-produced zero emissions vehicle and was launched as part of BMW's electric vehicle BMW i sub-brand. It is a B-segment, high-roof hatchback with an electric powertrain. It uses rear-wheel drive via a single-speed transmission and an underfloor lithium-ion battery pack ...with an optional range-extending petrol engine.[15]
The rex was an option, not a separate model.
Errr ?, yes….i actually said that TO YOU way back in post#83,..when you were arguing that a hybrid is considered an EV !
“.you're calling a hybrid a gasoline vehicle, that's dumb. Most sources consider them EV's, *because they have batteries and electric motors* You can't reasonably call a hybrid a typical ICE vehicle, so you're comparing oranges to apples.”
….Where as now you seem to suggesting the opposite….that a hybrid is just an ICE with an electric drive ?
POST#83
a Hybrid is just that.. a “Hybrid” (not a PHEV, or a BEV)
All its energy comes from the gasoline it burns, some is stored in a battery ( kinetic regen) for reuse via an electric motor.
BUT… as i also said, the hybrid RECOVERS the kinetic energy that would othewise be wasted as heat in the brakes, stores it, and reuses it to power the ancilliaries
Why are you so adverse to the differentiation of BEVs, HYBRIDs, and ICEs, as 3 very different technology groups ?
depends on who you chose to believe ….
2013 saw production i3s released to the public, launched at that year’s IAA Frankfurt show, with 46 BMW dealers refitted or created to sell as BMW ‘i’ outlets.
Pure electric (BEV) and hybrid i3 (Range Extender/REx) models were available from the start, …….
.. The second model, sold as the i3 Range Extender (REx), paired the same 18.8 kWh battery with a 38bhp, near flat engine adapted from BMW’s C650 scooter. This 647cc ‘twin’ was built in partnership with South Korean motorcycle manufacturer Kymco, and was completely re-engineered for its role in the i3 to fit above the motor and control pack in the rear of the car.
Electric motor does the job of:
Gearbox
Clutch
Starter
Alternator
Advanced Fuel injection *
Electronic ignition *
Variable valve timing *
Variable length intake system (and exhaust if it were at all particle) *
* A fixed rpm engine can easily be tuned and way better optimized without fuel injection, electronic ignition and variable valve timing.
The intake and exhaust pipe lengths can be optimized and remain optimal for a fixed rpm.
It is only at a constant speed, with the fixed rpm ICE geared to drive the vehicle at that 'one' speed that a direct connection is more efficient.
NB that BYD's upcoming Series hybrids are said to do 2.9 l/100km (81mpg) using series hybrid most of the time and changing to a direct drive top gear when (occasionally) appropriate.
BYD also uses a few other Ecomodder tricks like a lithium battery for the 12 volt system, louvered grill, LED bulbs everywhere.
