That may be one idealistic definition, but good engineering can also be defined as any solution that improves the efficiency, performance, simplifies the construction, or reduces costs , of a product.
EG, there is a very good reason why many heavy goods locomotives are diesel powered, but use electric traction motors..
1). It eliminates the need to electrify millions of miles of rail systems if only electric drive was used
2). It eliminated the hugely complex and expensive transmission and drive line that would be required to transfer the huge torque of a large diesel engined train to multiple traction axles. Electric motors on each axle is simpler and cheaper.
So, using 2 systems to do one job solves many problems and reduces costs.
Similar could be said for the use of Combined Cycle Gas Generation plants, where both chemical energy (gas turbine) is used in conjunction with thermal energy ( steam turbine ) , to do the same job .(.power generation), whilst improving efficiency and reducing costs.
