TSDZ2b kit on a gravel bike
baisikol
Not sure what this means
This is a unstructured review of a tsdz2b motor I used to convert a gravel bike into an ebike.
The base bike is an aluminium 1x12 gravel bike with through axles and 68mm bottom bracket.
The conversion kit was purchased from pswpower who ships from inside EU. Actual purchase portal is on aliexpress and there are few customization choices.
Engine I selected is 48v/500W, display is 850c and battery of 17.5aH (HL-plus). The cost of the kit was 570€ shipped.
The kit arrived in a bit over week, few days longer than shipping promise was. Everything one could assume is included, is.
The motor, rpm-sensor for rear wheel, y-split to the rear fork to attach lights, battery holder, battery, 2A charger, various fixing screws, cranks, pedals, throttle, display, tool to tighten bottom bracket.
I did not plan to have the throttle attached so I am not interested in brake sensors nor gear-shift sensors.
The installation manual is rather short, but it actually is pretty much as simple as that. I did watch the manufacturer installation video on youtube which was helpful.
What you extra I needed: various length zip ties, 5mm and 8mm hex socket tools, torque wrench, front and rear lights, xt60 connectors to replace the bullet connectors, soldering iron, a broken fatbike inner tube, original bottom bracket removal tool
To start, I cut the bullet connectors from the battery holder and the motor off and soldered xt60 connectors in.
Installation begins with removal of old bottom bracket. After that is done, the fitting of the engine can begin. With the bike I had, this was very simple, I could just push the brake/shifter cables aside, push the engine in and place the cables in appropriate places where they're not in the way and can still work. Fixing the motor in place is done using a tightening plate in the rear fork and this was a tight spot but eventually it worked out just fine.
Battery holder comes next. Since the bottleholder screws are so close to each other, I drilled space to the top of the holder to allow a thick ziptie to fasten the top part to the frame. Thus, the holder is held in place by 2 bottleholder screws and a ziptie.
Lastly it's the fun part, which is cable management. A lot of zipties and happythoughts later, it will not look like a bike from a factory but hopefully something you won't feel ashamed riding on.
The installation took a day for me with long pauses between. This was the first ebike I've built with a little experience in electrics and bikes.
So far I've ridden about 100km with it. The first ride was 2x27km at max assist level on a -4C weather with variable road-profile and a mass of around 100kg on the bike (+10kg bike, +10kg motor/battery). The battery was almost empty after the ride. Second rides were 1x27 with battery at around 49v at the end.
The assist feel very much the same as it does on my factory built fatbike with a M400 bafang motor. It does have a sharp kick-in/out, and riding at the threshhold (the maximum speed I've set it to assist at) can feel bouncy. I knew before I bought the kit that the 42T chainring will not work and it doesn't, I only use the 5 lowest cogs on the cassette and they'll likely wear out very quickly. A 52T chainring is a must for this bike.
The tool for tightening the engine (the included BB tool) is bad, you're supposed to tighten the BB to 40Nm but the tool cannot be attached to a wrench. I've already once had to undo the pedal to tighten the BB and it's loose again.
FME with a BBS02, if a lock ring secures the system, a Hozan tool is very effective; I beat on it with a hammer and it hasn't loosened in eight years.
The BB coming loose is apparently a fitting error on my side. Either the plate used to secure the motor to the BB on the other side was too far away (I used two washers between) leaving the tightening piece loose or the motor collided with the frame on the other side disallowing the BB to be tightened.
I put a washer on the fixed side and left one washer off on the other and the BB seems secure now after two commute rides (totaling around 120km).
To clarify, see the attached picture > Washer added to where the green is, one washer removed from where the red is.
I also have had one problem with the motor, during my third commute the engine stopped assisting. I stopped and it seemed like walk mode was enabled (the motor pushed forward at a slow pace). I turned it off and back on and got error 04h. It's throttle stuck error which seemed odd because I don't have throttle. It must've been moisture getting into the throttle connector as it was raining and I had not properly clogged it. It's clogged now and the problem hasn't returned.
The mainstream thoughts for mid drives are that they should be spun fast to be efficient. That imolies 52T will be too high, unless you're really flying. Maybe you are, as you're burning 15AH (700+ watts) to cover 54 km,
I ordered a 50t chainring. Cadence calculator suggests I can use 15t rear sprocket to maintain a speed of 30,2kph at 70rpm with 50t instead of 29,2kph with 13t rear sprocket with 42t chainring. This is the reason for bigger chainring - I dare not forcefeed the 11/12/13t sprockets because of bad (excessively worn chain, worn chainring) experiences with my other middrive.
However, now that I've driven about 500km with the bike, it looks like assist level 3 is perfect for riding. The bike feels very natural at this level and the threshold is not noticeable.
Great to read this post as it’s exactly what I’m looking to do with my Trek cyclecross.
I’ve currently got a 2x9 setup with a 50T and 36T front chainring set.
So with converting would o be correct in thinking I will be going down to a single chainring on the crank? Should o look at a 52T?
I’m only wanting pedal assist like you, don’t want throttle as I simply want assist in the hips as they are plentiful where I stay.
Can you send a link to the video that was mentioned so I can get a look at it?
Thanks
Mark
The front chainring size you pick will usually be whatever gives you the pedal gearing you use the most in the worst conditions you have. You'll want to pick one that lets you still ride even if the assist fails, in whatever conditions you must still ride in if that happens. (or else walk the bike).
You can be limited by the specific middrive and the specific bike frame because of chain alignments, sprocket sizes taht will fit on the drive, etc. Sometimes you can change the rear cassette and derailer to compensate for this, to give you a bigger or smaller rear cog to fix having to use a smaller or bigger front ring than you want.
After ~4400km, the engine is beginning to break. There is squeaking sound, it makes crunching sound when pedaling very slowly (and the motor wants to start assisting) and doesn't actually assist when it is supposed to. The voltage drops so something is happening with the engine but the power is not transmitted to the chain.
Before that, the charger that came with the package broke down.
So, on my personal experience for 1/1 engines, they're not very reliable.
Thanks for your report, and it seems to echo what some (not all) others have reported with TS motors.
After ~4400km, the engine is beginning to break. There is squeaking sound, it makes crunching sound when pedaling very slowly ...-... So, on my personal experience for 1/1 engines, they're not very reliable.
Have you done any maintenance during these 4400 km? Because from everything I've read, the engine is quite reliable(especially TSDZ2B), but with regular maintenance. Also, its repair doesn't takes a lot of time and money.
..that's how I got rid of the squeaking of those darn tapered spindle on the tsdz2b, wouldn't go away untill I got mr. Mallet and let him help a hand..
There are many parts not related to the motor which can squeak ( especially that tapered spindle if you don't tighten your bolts enough ).
Crunching sound is worse though. I had it a bit to, but when I took apart the drive side there was some dirt ingress. After cleaning that, no more crunchy sounds for me.
If your motor sounds like it's engaging, you hear a lot of crunchy sounds and you're not getting any assistance, you probably mashed your nylon drive gear. Replacing isn't really hard, and replacement is cheap. But I could be wrong, it's up to you to open it up and take a look.
Charger I got with my purchase from pswpower is a normal EU certified charger, unlike the one with the battery pack I ordered straight from Ali. They didn't even bother trying to put on stamps/stickers claiming to be compliant. I consider the Ali battery pack and charger both a fire hazard.
Thanks
Mark
Sorry I missed the request for the video, you probably aren't needing it anymore but here it is:
No, I did not catch on any maintenance recommendations for the engine. The manual didn't suggest any either.
The engine has now been replaced by tsdz8 which feels like a bad-behaving big brother. Pretty much the max assistance I've been using for this is 60% and the front chainring is worn useless after 800km. To make that worse, it seems this chainring is quite custom and not easily replaced. At this point I might opt to just move closer to where I work so I don't have to deal with ebikes at all :D
Yes, I have already figured out this motor(tsdz2b). It's enough to add 2-3 extra bearings, lubricate the axle where it touches the big clutch bearing with graphite grease and main "blue" gear (and repeat it every 1000 km). And also modify the cooling. And that's it. This engine will serve for 10,000 km more.
P.S. the biggest advantage of tsdz2b vs tsdz8 - it is smaler, lighter and easy on the battery - in 2 times almost.
I think in another thread it was mentioned that this is the only off-the-shelf chainring adapter available for TSDZ8.
My TSDZ2 was starting to creak again,, so I took off the pedal, found my TSDZ2 BB wrench and tightened it with a hammer. I thought about bolting the tool to a 3 foot piece of angle iron. Next time, I 'll do that. I moved the fastener about 10 degrees with the hammer..
It was at this point that I thought I would insert those 6902VRS bearings to beef up the axle. One on the non-drive side. There is a rubber cap that pries out easily. Be careful, as it has a spring inside it to push the rubber against the axle.
Then the new bearing is pushed in. I used a socket and tapped with a hammer. Tight fit. Now I wonder how I will ever get that bearing out, if I want to take the motor apart to reach the circlips on the non-drive side. Let's hope that never comes up,
I suppose I will have to pry the dust cap off the bearings, insert a bent pry rod and try to hook it out?
