DanGT86
Power poster
Thinking about trying a Gates CDX carbondrive belt in rigid setup mounted to the LH disk flange. Since they aren't cheap I'm wondering if anyone knows the max force the are designed for. How far can I cheat the max rated power of the belt with a high gear reduction?
I'd be using a 19tooth front pulley and a 70 tooth rear. I am aiming for about 3kw with 1500rpm at the small driving pulley.
Without a spec from gates I have to make assumptions based on the human powered bikes and low powered ebikes these are successfully used on.
Anybody ever seen chart/formula/matrix for Gates CDX belts that shows max power as it relates to RPM? I have seen these charts to calculate power limits for the GT2 and HTD series of gates belts.
Another big unknown for me here is optimal tension range with spring tensioner and full suspension. I've been seeing a lot of full suspension bikes using these lately so I'm assuming the recommended tension is a range that can vary enough to be achievable with a tensioner.
After using a waxed 219 chain on my LH drive bike I am convinced there is no good way to keep chain lube and wax off the brake rotor so I am really wanting to try out a belt.
Any belt experts out there that can tell me if I am crazy and or bad at math?
- On a normal bike or mid drive ebike these belts can handle 750-1000watts at 60-100rpm.
- With 40-50t chainrings and cogs in the 20s this is about 2:1 overdrive
- So if I am running 19:70 which is about 1:3.6 then does that mean over 6x the power for the same belt pull force?
