BiggKidd
Established
BTW I hope you like yours at least half as much as I like mine. I'm amazed at the places it'll go and the hills it can climb.I got a e26 pro the headlight doesn’t turn on, and solutions.
Thank you, I’ll try it tomorrow morningYou have to hold down the up button for a couple seconds to turn it on. It's not the on off switch that controls the front motor.
If that isn't it make sure the plug is fully seated.Thank you, I’ll try it tomorrow morning
Did not workThank you, I’ll try it tomorrow morning
Sorry to hear that. I'm guessing you haven't tested the light itself? If not the first thing is to make sure the light itself works. Is the tail light and or brake light working? Turn signals? You may just have a bad light. If it does work when powered directly if it were me I'd pull apart and visually check ALL electrical connections on the entire bike's system. If you do that then don't find anything and it still doesn't work after that contact customer service, they were good with me. A lot of times just a plug can be loose or not seated properly and the act of reinstalling them is enough.Did not work
I just got the Ridstar E26 and the throttle is not working. Do you have any info that could help? Thanks!I bought a Ridstar E26 week before last and have put 168 miles on it as of today. The picture was taken a week ago. The bike performs flawlessly so far and without the front motor would be in a world of hurt with the hills and mud around here. It doesn't have the power the seller advertises unless my math has gone to pot. I say that because it claims 1000 watts on each motor yet the controller is set at 12 amps 12A times 48V is NOT 1,000 watts. Having said that it has power enough for most terrain. With both motors it's about 1,100 watts IF it's using two controllers at 12 amps. The controller(s) can be turned up as high as 20 in the M5 display. I personally don't see the need to turn it up at this time. I would like to figure out how to adjust the MPH of the PAS settings. It uses the M5 display if anyone knows how I can change the PAS speeds? It would be nice if I could set PAS 1 to about 7-8 mph for rough off roading which I do two miles of every time I leave the house before I hit pavement and PAS 2 to 15mph for easy pedaling at slow speed for battery conservation. As it came PAS 1 does 13 and PAS 2 does 18 which I have to pedal faster than I'd like to help the motor along in PAS 2. A larger chainring is coming next month I hope, that should help alleviate that issue. Maybe I can even get the gearing up enough to pedal along helping at even higher speeds like 25. It looks to have a 48 tooth chainring now and 52 is about as high as I see for sale right off. I'm also trying to figure out if I will need a longer chain for that swap if anyone knows? Also if anyone knows where I might find a sprocket larger than 52 teeth for it? A link would be great! It uses the tapered square drive type chainring and crank arms.
I have a new handlebar supposed to be here this week, one with 120mm rise. Why in the world do they put these flat bars on this type of bikes? It makes it so the rider has to stay hunched over all the time.
All in all my only regret with this bike so far is that I didn't buy one sooner! It looks, feels and rides like it's well made and I have been thoroughly enjoying it. It has full suspension with a nice rear rack and came with DY Island hydraulic brakes, headlight, turn, tail, and brake lights along with a horn and cell phone holder with a charging port. It uses the same basic 7 speed as most of these bikes.
The only gripe I have with it at this point is no regenerative braking. I could really use it with the hills we have as I often worry about over heating the brakes and miss the power that could be generated going down these hills. Welding up the freewheel in the rear motor isn't an issue but I don't have any idea if it would work with the electronics is has. If anyone knows please shout out!
I'm sure everyone wants to know the top speed and miles it can travel on a single charge. Well top speed is just over 30mph and in PAS 1 at 13mph I've gone 41 miles and still had a little juice left when I got back home. Now grant you I was pedaling the entire time and using every trick I could think of to extend the range as far as possible! The battery is a 48 volt unit with 23AH of power storage.
I did order and install Flat Out in both tires after seeing so many complaints about how easy these tires puncture.
If anyone has any questions or comments please feel free to ask or comment.
Not right off other than to double check all the connections / wire plugs. You do have to be in one of the PAS 1-5 settings, on 0 it will not work. I think there could also be a setting in the display that could be off besides that one that could also cause that.I just got the Ridstar E26 and the throttle is not working. Do you have any info that could help? Thanks!
I’ve emailed and called, no response. I tried a different headlight with no success.Sorry to hear that. I'm guessing you haven't tested the light itself? If not the first thing is to make sure the light itself works. Is the tail light and or brake light working? Turn signals? You may just have a bad light. If it does work when powered directly if it were me I'd pull apart and visually check ALL electrical connections on the entire bike's system. If you do that then don't find anything and it still doesn't work after that contact customer service, they were good with me. A lot of times just a plug can be loose or not seated properly and the act of reinstalling them is enough.
I bought my bike off Ebay and contacted customer service of Ridstar by Email several times with questions and such after purchase and they always replied within 24 hours, usually in the wee hours of the morning AKA working time over there.
Wow that's surprising they treated me well E+mailing through Ebay. Other than checking the connections I don't know what else to try without searching it out from the main power wire to the light through all the switches etc. with a test light and multimeter.I’ve emailed and called, no response. I tried a different headlight with no success.
I'm just over 6 ft maybe 6'2" in boots and this bike is a little taller than is actually comfortable for me. If you have long legs you may want a bit of post extension or maybe a suspension seat post as they add a few inches. I have the seat all the way up for proper leg geometry but then I can't even come close to touching the ground from the seat.Hey guys brand new here, just ordered a e26 pro was wondering if anyone could recommend what accessories to buy and what eu website to buy from or website that ship to eu, I just want to make my commute as easy as possible and I’m a bit worried I won’t be too comfortable as I’m 6ft 7 and just after knee surgery, but I have been researching this bike for weeks now and it seemed to be the best fit for someone my height
To be honest people say I have the body of a gorilla lol 34 inch legs and then a massive torso lol , sorry if I’m bothering you but do you have any recommendations on what makes and upgrades I should do, and the skill level involved to install , this is my first e bike that I own, I have ridden them in the past and I have cycled regular bikes not for a while lol, and motor bikes, are there any essential accessories I should purchase, I’m going to be potentially using the e bike 5 day a week for a commute to work as this is a way cheaper alternative to getting a second car in the house the commute is approximately 10.2 miles round trip, and I’m trying to find any videos on the e26 2000w and I’m struggling to get any information except from ye guysI'm just over 6 ft maybe 6'2" in boots and this bike is a little taller than is actually comfortable for me. If you have long legs you may want a bit of post extension or maybe a suspension seat post as they add a few inches. I have the seat all the way up for proper leg geometry but then I can't even come close to touching the ground from the seat.
Mine had issues and Ridstar support sent me a new one. I also needed a new controller and they sent me one too. They are fairly responsive, overnight response. They may want to troubleshoot with you, depending on the issue, and that takes a day per step, but they worked with me. Hopefully that's helpful.Hello i just wanted to ask where can I get a lcd display that will work with the ridstar e26 pro
