Yeah, I wouldn't have mounted all the way to the top. I figured 2 inches higher than my current setup.It's going to be more stress on the headtube of your frame, you need to decide if that's a gamble you're willing to take. Since its a dual crown you may be able to limit the travel internally and lower the crowns on the stanchions to compensate.
Just curious--how did you determine how much change would give how much better higher speed stability?What are the issues with running a longer fork? I'm trying to get more angle for higher speed stability. This would be a dual crown setup btw.
It might not solve your wobble issues. That can be related to tires or tire pressure, bearings, or worn front or rear suspension components. Are your headset bearings in good shape?I understand. I get front wheel wobble past 50mph. Currently I'm running a taller rear wheel which is effecting the angle. I figure I can get maybe 5 degrees more rake to solve the problem. Plus I hate the current front suspension.
It can also be caused by frame flex.It might not solve your wobble issues. That can be related to tires or tire pressure, bearings, or worn front or rear suspension components
I lean toward the headset, only because when I had a headset issue (binding/too tight), my bike was super dangerous to ride. I had a similar thing on one of my motorcycles after a crash. The forks were of kilter in the triple clamps, with a similar binding in the headset. I was able to ride home and straighten things out. The amount of movement required to ride a bike without tipping over is tiny, but if something impedes those tiny movements and it gets scary fast.It can also be caused by frame flex.
Do both forks have the same travel?Just a matter of 20'' or 26''.
I haven't chosen which forks I'm going with yet. Thanks for the information. My current head tube angle is 75 degrees. That seems way steep to me. I'm shooting for 68-72.I lean toward the headset, only because when I had a headset issue (binding/too tight), my bike was super dangerous to ride. I had a similar thing on one of my motorcycles after a crash. The forks were of kilter in the triple clamps, with a similar binding in the headset. I was able to ride home and straighten things out. The amount of movement required to ride a bike without tipping over is tiny, but if something impedes those tiny movements and it gets scary fast.
My frame has a slack head angle and was designed to work with a broad range of fork lengths, depending on application. For cross county, 115mm, for freeride, 160mm, the former being more nimble at slow speeds and the latter being more stable at higher speeds.
Most 20" forks average between 80mm to 100mm travel and 26" forks between 100mm to120mm. You could have longer travel versions of either. So going from 20" to 26" will provide a 76mm increase in height (and corresponding change in head tube angle) due to wheel circumference, plus or minus the difference in travel of the two forks. A 20" fork with 80mm and a 26" with 120mm, is different than a 20" with 100mm and 26" with 100mm. My frame geometry handles a 45mm difference in fork height fine. Not sure about 76mm (or more) though.
Thank you. Far from ideal, but it'll have to do.
Appears near zero or negative trail.
I'm part of the problem here. I changed the stock rear shocks from 330mm to 360mm...Thank you. Far from ideal, but it'll have to do.
