tombenn444
🔋 Established
Hey everyone The death machine Rider here, I would like to walk you through each step of this build taking feedback as is given and considered. Got a 20" giant revive semi recumbent that's gonna be paired with a 3000w 72v bldc China motor and a 80A China controller
Okay first I was going to put the motor on the rear rack because it seemed the most obvious and convenient but I would have to sacrifice my suspension for that so im putting it down low near the bottom instead. That should help it stay a little bit more stable at high speeds cuz I'm going to need every single bit of help in that area as I can get. One thing I do not like about this bike is there's no steering adjustment to tighten or loosen the play. But it has instead is a spring that is hooked behind the fork to the frame itself I'm not sure how well this will work but we'll see. I might just have to put a bigger spring on if need be. I'm curious as to what bigger Wheels will look like with it raised up and maybe different front end but that's for another day.
Anyway,
First off, I took the rear rack plate off trimmed it up a little and made a hole for the rear shock to fit through I would like to mount the motor right in front of the suspension I might could get it behind it but it's kind of tight. The controller will fit on the rear rack and self because it's just a perfect after I get the motor mounted I'll have to run the wire through the frame then Mount the battery.
Anyway,
