Building my first e-bike, questions
I have a theory that rims are the suspect for flats, and changing a flat on a motor wheel locked down with torque arms is a hassle, not to mention the danger of a front flat while going 20mph. Slime tubes are a joke, and messy. Anyhow hope you are having a good ride!
Next good day I will give it a more thorough test, The new seat is not here, but the 30A fuses and tiedowns arrived.
Rode it 7 miles, and it works great! Battery was at 75% when the ride was finished, My only pedaling was on the steep hills, and it wasn't bad. I wanted to test out the system worst case, by me doing the least, top speed was 26mph, I have the "road legal" wires connected, and amperage limited to "20 amps" according to the controller, but I think it is still putting out more.
Pedal assist is not hooked up yet, I have to get the tool from a friend of mine. What level should I charge it? 100% before a ride, or less after a ride? New seat soon! (below), my butt is too big for the original one! Edited for clarity.
That seat is more than adequate even for a giant butt. You can't expect to be comfortable immediately while doing something you have no conditioning for. Fine tune the angle and give it a few rides. It's as likely to be too big as it is to be too small.
MUCH has been written here on ES about maximizing Li-Ion battery longevity by not charging to 100%, nor discharging to 0%. You can search around here a bit to get a feel for it.
Easy rule of thumb for you at first: Limit charge to 80-85% before a ride, don't discharge below 30%. No need to charge immediately after riding-- the battery does better stored at 50% or less (say 35-50%). NEVER let the battery sit at 100%.
I have a theory that rims are the suspect for flats...
My own experience with flat culprits is (in order):
  1. Glass shards
  2. Bits of wire (as if from a wire brush)
  3. User error (pinch-cutting the tube when using tire spoons sloppily)
  4. Screws, nails, etc.
A few times over decades a rim has fractured or separated at the side braking surface which caused an immediate exciting blowout.
"which caused an immediate exciting blowout." certainly don't need that... I have also heard low tire pressure, and curbs will do it
Drove another 11 (18 total) miles without charging, down to 64% Blew the 30a fuse 2x properly in the middle on tough hills, I set the controller to 15a,(p14 on the controller) and it seems to make no difference, still getting 900+ watts (36V) with full throttle. Controller still says 100% battery, I think it is set for Li-on batteries, instead of Li-fe , I don't think that can be changed. Fuse holder and fuse is not really hot, but the 30a Chinese fuses may be the issue. I dunno...
Is this that customer-return kit? Maybe the problem is that the display isn't sending data to the controller or controller isn't receiving it. In that case, no changes you make to the settings will be saved to the controller, so it will just run at whatever it's power up defaults are. Does it change behavior in any way, based on assist level changes? If not, this is a likely problem. Some systems give a comm error (E30, etc) in this event, but some only do that when the display can't read the controller, not when the controller can't read the display.
It can also be that the display has the wrong firmware for the controller it's paired with, so that it's data is the wrong format or the wrong values, so the controller ignores it. That's less likely since the display is providing you with the watts (which has to be calculated by the controller, or is based on amps that has to be calculated by controller).
I have a Lishui-based system with Kingmeter display, IIRC, that always reads as if it was LiFePO4, and all the Lion batteries read full even when they're not until they're much less than full because it expects a lower voltage total.
If yours reads full even at only 64% for a 12s LiFePO4 battery, it's probably not using the right battery voltage range or is set for the wrong battery voltage entirely. Your battery should be at about 3.2v x 12x = 38.4v. Is that the voltage you see at this point?
A LiIon battery at that SoC is probably around 3.8 per cell, at 10s, so around 38v, so even if your display's meter was set to LiIon it should still show about right for your battery.
If your display is set to 24v battery, then it would show yours as full all the time, even when completely empty.
If the fuse holder or fuse are increased temperature under normal operation, something is wrong--either the parts are defective, or insufficiently capable for the current flowing thru them.
Also, keep in mind that fuses are "precision" parts, in that the fuse wire itself must be exactly the right metal composition and the right thickness / length / etc in order to correctly blow for a specific current rating.
If you look at the spec sheets for fuses such as those at Eaton / Bussman / etc, you'll find a chart in them that shows you how long a fuse takes to blow at a specific current. That is so that a fuse can be properly specified for a system, so that it will blow before wire / etc damage occurs, but will *never* fail under normal usage. It takes a certain amount of time
To pick the right fuse you need to know how much current you will have in that normal usage, *and* how much current will damage your wiring that the fuse is protecting (all the wire beyond the fuse point, which is typically right up at the cell block inside the battery, so that any short circuit that could cause a wiring fire instead blows the fuse without damaging any wiring). It
So the smallest wire in the battery + or - wires (the current path) is the weakest point, and whatever current it is meant to handle is the limit to pick the fuse for--the fuse should always be picked to blow before that current is reached.
But the fuse should be picked to never blow when normal usage current is reached and sustained, "forever".
If the fuse keeps blowing, then one of these is typically the problem, in the order they usually are seen in:
--a wiring fault exists (intermittent short, damaged insulation, etc)
--fuse is sized too small for the load it must handle
--fuseholder is not holding the fuse right and causing so much heat it melts the fuse; this always causes wiring insulation damage and usually causes melting of plastic parts nearby.
--fuse is defective or poorly manufactured
If you can do 100% before a ride, no one will complain. If you do it after a ride, that hurts longevity, but it's LiFEPO4 isn't it. I thought those lasted for thousands of cycles with most any charging scheme.
Yes it was the customer return, It looked like it was never used, except for the shipping damage. The controller "works properly", in that the settings are saved, and when I mistakenly set the wheel size to 20 inch, the bike got real fast. The pas is set at max, but the sensor is not installed yet, so it is inactive. My battery voltage rating on the label is 39.6v at 364 wh and tops out at 42.5v at full charge. The controller is set to 36v. The controller is rated for 26a according to the sticker, and the default setting in the controller. I installed 30A, because it is not supposed to blow at currents below that level. Unless the amp rating is average current, there should be no issue. Last time the fuse blew I set the controller current limit to 15a and it still output 900+ watts and the fuse blew again later. There are no shorts, no chaffing wires, and great performance,si I don't think much is wrong. There is one thing, I just thought of, is to disconnect the electronic braking, it may affect something, as I installed the wires to the board.
My battery is 12s, and the display on the battery is configured for that. top charge for LiFe is 3.65v which is 43.8v
so the battery meter on the pack is pretty accurate, my charger cuts off to a trickle at 42.5, unless I leave it on for an extended time, but I am not comfortable leaving it unattended. The fuse holder does not get excessively warm.
Likely
-fuse is defective or poorly manufactured. I will buy a pack of fuses at Napa, and try again
The battery meter "works" but the battery is out of juice at 50% on the bike, basically maybe 5% left at 50%, then shuts down, so the pack lasts about 20 miles total, then I'm pedaling, no real reserve. when the battery meter on the controller drops 1 bar, it's time to head home. The meter on the battery drops the last 50% really fast, the bike stopped with 10% on the battery meter.
I have to take the battery apart and recheck balance on the cells, I was under the impression the original BMS was working, but I need to verify it. I think the capacity is pretty close, as 900+w for 20 minutes seems plausible for my rides.
You want to be able to see the voltage while you are riding. Consider moving the V meter so you can.
Have you checked the P groups for balance? Is there a BMS?
You bought a used pack. You may want to check its capacity with one of these https://www.aliexpress.us/item/2255...st_main.5.45f01802MD8CvD&gatewayAdapt=glo2usa
Very useful device to check status of any battery.
Last time I used mine was checking capacity of two different brands of 1.5 V AAA and AA Lithium rechargeable batteries that turned out to be 1/2 of rated spec (mWh). There were 2 other brands that were close to spec so I kept those. Returned the others. W/o the capacity tester I would have no idea.
When I first got the pack, I did check balance, and it was very good, now that I have cycled it a few times I can check it again.
There is a BMS, but it is uncertain if it is working properly as used, that is the reason I need to check the balance.
Off the cuff I think the capacity seems within reason, and although i would love to have another tool for measuring, I think I will wait until I am building packs before buying that cool tool. I will just charge the battery before a ride, as I am unlikely to exhaust it normally. I just ran this battery down to get an idea of it's capacity.
I did 10 miles today, no real issues, I still have to try a few things, (still not limiting current 900+watts no matter the settings) I'm waiting on a tool to take the crank apart to install the PAS sensor. The new seat is awesome! I need to pick up some screws to finish up the controller mounting. The new bungee cords work fine for the battery. There is a blue wire that has something to do with "road legal" I'll disconnect and see what that does Electronic braking is nice and smooth, without being too strong, so that will stay. I still need us made fuses, to see if they will blow If I push it. I didn't blow any fuses today, but I was reducing power a little on hills and doing more myself. top speed is 28 mph approx with good power, so I can pedal for a while, and when I get hot and tired, the bike can take over, and cool me off again.
Maybe try a circuit breaker? I believe this is the one that E-HP used successfully..
My fuse problem was a Chinese fuse, it would discolor inside(they start as silver, and turn dark grey) during a ride, and if pushed, it would fail. I replaced it with a Buss fuse, and there is no sign of an issue, and I really punished it hard today, I rode about 12 miles full send without any pedaling, 27mph pedaled on some hills, 900 watts most of the time on the display. I'm happy with it, I have some maintenance to do on it, the 25+ year old derailleur cables are stiff, and some things need to be oiled. The "front shocks" are a little stiff, and need some lubrication also.
I will need a new rear tire also as it is also 25+ years old as well. Still waiting on the tool to install the pedal sensor, it's almost a month!
First 100 miles, everything is working well, I took the battery apart, and checked cell balance, and it was right on, within .1v cell to cell, so the balance part of the BMS is working as is, The controller shuts the bike down without over-discharging, and it is protected with a 30A fuse, so I will call it finished, Eventually it will get a better rack when this one fails (and it will), and the PAS sensor installed. i really like the way it rides, the "suspension" is working pretty good for me.
No, it's not. 0.1v difference between cells is really really badly unbalanced, with large capacity differences between them.
The usual cause is mismatched, worn out, or recycled garbage cells, any of which makes them so different in properties that they will not ever perform the same as each ohter, so they will always be or get unbalanced.
A good working well-designed BMS will turn off the charge and discharge ports for cells that badly mismatched, because of the risk of causing cell damage from overdischarge or overcharge, etc., or of there already being cell damage that is causing the difference in voltage. Such damage could lead to a fire, so a good BMS is designed to prevent use of such a pack.
0.01v would be acceptable cell difference in voltage, but even that indicates mismatched cells.
So, it's been a while. I put another 30 miles on it in the this week. The BMS had an issue during the winter, so I replaced it with an active balancer, I lubed the cables, and things are working pretty good. I'm pretty happy with it.
If something catastrophic happens, I would look for another bike, as I'm getting more into biking more as I get more experience with it. I'm still a little rusty this spring.
