Dui ni shuo de dui
Power poster
Hello guys,
My lead acid car battery has been showing signs of aging recently and it will probably be time to replace it within a few months.
Just to be clear, it's not an electric car, it's a petrol engine and I'm talking about the battery that helps with cranking and whatnot.
I'm toying with the idea of making my own battery, mostly for fun but also in order to get slightly better performance (my car is very, VERY sensitive to battery health and all sort of electrical gremlins tend to pop out when the battery is not in perfect health)
Anyway, I already know what cells I'd like to use, I'm already familiar with making DIY batteries, connecting and configuring the BMS and whatnot.
But for this particular project I'm unclear about the charging aspect.
A a car alternator can output a maximum of 14.7 to 15V, and I'm planning on using A123 pouch cells that should generally not been charged over 3.6V per cell (so with 4S that'll be 14.4V).
I'd like to avoid overcharging the cells for obvious reasons, so I'm wondering how I should do this.
The BMS can be set up to cut the charge at any voltage I want, but I don't think it would be good for the car if the BMS cuts off the battery while driving. So basically I think I need some kind of charging regulator between the alternator and the battery in order to lower the voltage to ideally a maximum of 3.5V per cell. so 14V (slightly undercharging in order to increase longevity).
Anyone here with some experience of building a car battery?
Suggestions are very welcome
Thanks!
Thanks!
