BMS recommendations for 72V 160A 20P20S pack build?
BatteryManTakeMeByTh
⚡ Regular
Michigan
Basically title. I've heard Daly is either crappy or at least very hit or miss. I did hear good things around about the ones below:
Any feedback on these would be great, as would any recommendations. I'm new to the choices of picking BMSs, and I haven't found many sources out there that look legit. Happy to answer follow-up questions.
If it is useful, there are quite a few threads about BMSes here with info and thoughts you might need to consider before making a choice, regarding features and functions, wiring, installation locations, etc. Most of them are here in this subforum, though there are some elsewhere (mostly in the motorcyle and large EV subforums). (there are also individual posts in ohter threads, but most of the info should be in the BMS and battery specific threads).
(it is too much info to retype here).
I searched a bunch of threads, and I got the few links I posted from there. I know this is a lot to ask, but any chance you could link good threads you know of? I'll go looking again after I make some dinner.
Keep in mind that I'm not suggesting to find specific recommendations of a BMS in those threads...just that you can learn about the many types of BMS and what functionalities and features there are to be had, and then decide how you want your system to work, and then you can start looking at specific BMSes.
If you just pick a BMS, it may not do what you want it to (though you may not know that till later). We don't know what you want it to do, and it is likely that you don't know either as you probalby don't yet know what they *can* do (and can't), and the limitations of various types.
There are common-port, separate-port, FET-based, contactor-based, balancing, non-balancing, active-balancing, passive-balancing, dumb, smart, programmable, non-programmable, BT-enabled, hardwired-enabled, ones with screens, ones without, etc.
If I have time later I will see if I can find any specific threads discussing those and link them, but I won't make any promises. ;) (am in the middle of making a piece of music and am on a roll, but while waiting for it to render out some audio I came to peek at the forum, since JellyBeanThePerfectlyNormalSchmoo is somewhere else having a nap or something and isn't demanding my attention :) ).
This doesn't narrow it down much, but this link shows threads in the forums I mentioned (rather than eveyrwhere) with BMS in the title, by thread, by most replies (rather than newest):
There's still 70 pages, which doesnt' help concentrate effort much. :(
The first doesn't list enough specs to know much about it. The second one has a super low balance current for the size pack you're building (180mA). The third one is even worse with only 100mA.
I'm using one of these (100A charge and discharge):
I think there are versions up to 300A. The active balance current can be set up to 1A. It keeps my cells balanced out to the third decimal point. Supports 3 temp sensors (I'm using 2) for high and low temp protection, and bluetooth connectivity and setup. I believe the 100Balance brand is a subsidiary of Daly. I'm pretty happy with it. I can stay connected to it between the garage and upstairs, if I need to go in the house for moment, and my normal charging takes about an hour.
You can get an idea of how the interface looks in this video (the video has the wi-fi version, while I have the bluetooth):
Awesome, thank you very much. Clearly I have a lot more reading to do, but I will definitely look into this option when I have finally read up on the important specs and ranges for my voltage/current/capacity.
