escooterLover
Hello. New here. I'm so glad to see many healthy and up to date users here. It was difficult for me to find a forum on stand up escooters that had recent posts.
So I'm a proud of owner of 4 scooters; Vsett 10+, Vsett 9, and 2 modified Xiaomi Pro 2. They're all in my garage, and I mostly use the Vsett 10+ for daily use as its a reliable and powerful scooter. I modified it with a seat as I take my son to school etc.
With one of my Xiaomi Pro 2 scooters, it's modified with a first gen Monorim front suspension, rear 3rd party rear suspension. It has a hack in which I can modify parameters etc that go against the factory build. Basically, as you guys know, it can go like 42kph blah blah. I haven't tinkered it with for so long, but maybe I will as I learn from this godsend forum. So, this particular Pro 2 model has an external battery pack. When I bought this scooter second hand about 2 years ago for an amazing price, it came with the extra battery pack. I understanding the wiring, routing and tutorials via vast Youtube videos, but what I didn't know was the voltage or how this battery was set up. I took apart the ''casing'' or rather ghetto tape that held the piece together and I learned that there are 40 cells. It states 3.7v 2000mah. I can't read the ''ampage'' since I don't want to mess with the tape, but I will reorganize the ''casing'' later on. The battery works fine I just need to find a male connector for the recharging port since I couldn't find it anywhere. This battery has the common 10S BMS 20A. So what is this battery? Any tools I should buy or need to check voltage? I assume this is a 36 or 37v battery? Possibly a 48V? From my understanding this Xiaomi is running in parallel to the original scooter, therefore the custom battery when made had to match the original battery under the base? I want to learn these things. The original owner had told me to unplug the battery from the scooter when charging it. Meaning, charge both the external battery and the scooter separately. So what would that mean? At any rate I am very happy because everything works and I've never had problems.
So my other question is. How do I know the state this battery is in? I know all batteries have shelf life for charge cycles etc, and I assure this Xiaomi is barely used. I am eagered to make a new one, but I need to learn voltages. For example, can I make a 48V battery with that common 10S BMS 20A controller?
I was thinking of maybe trying to make a 21700 Li-on battery instead of the 18650's. Isn't it same concept? The difference is that the bigger batteries have more ''juice.'' I plan to buy know brands like LG, Panasonic or Samsung etc. I would greatly appreciate any advice as I would love to dive into this nerdy-Warrior world escooter modding and be a part of your community. Thank you so much!
