Hi. Wondered if any others have issue with chainring play on Toseven DM02 or 01. Pretty sure it was very little play when new. I have two chainrings and derailleur, so with the play chain is rubbing a little bit. The axle that holds the pedal has no play, except sideways which is normal. But the assembly with the big gear and chainring mount has play. I replaced the small bearing between axle and chainring mount(16.30 in this video,
), but that was not the problem, same play after. So if someone have had this issue and fixed it, let me know please. I tried Toseven, but got the : I have to tighten the chainring nut answer, among other likewise answers, so have given up on that.
