So you laced up the rim?Well, I have just competed my finest ebike conversion yet--finest as in least expensive. The battery and motor came out of an Aventon Pace 500, which had rim failure at the spoke holes. The bike stuff came out of a pile of free bike parts. About a two hundred dollars, excluding the new tires and tubes.
I built the bike for a friend who has COPD, so no pedaling is expected. It's a quick bike.
The before picture is when it was going to be the test bed for an experiment with super capacitors, which didn't happen.
I've laced 1 wheel to date, got it true, hit about 3 curbs, getting it true every time.Yes. I've laced 3 motor wheels to date.
Yeah, kind of seems that the second picture and the third one got mixed up.Curious the reasons for landing on a hub motor from the BB mid-drive set up? Did your first set up have the hub motor too?
I have bought a couple of the 36 volt 500 watt DD hubs off Amazon they can be run on 48 volts and up to 1000 watts I would think decent quality for a cheap build.I must learn not take any more strays home with me! This was an unwanted bike from a yard sale down the street, so I took it home:
Of course I just had to put a motor in it:
Rode it to the top of the hill and it works well. Throttle and cadence PAS. Running at 36v on a test battery.
The labeled 250w motor howls on high loads.
I keep trying to build a decent ebike at low cost, but with this bike I learned a lesson. Don't buy a cheap motor, and then waste your time and money putting it into a wheel.
ink
About $400 into it, but I plan to go to 48v, which with surplus batteries is another hundred.
It goes 25mph on electric as is, which is fast enough. As I already ordered the batteries I might as well see how it does on 48v.
I spotted a 'Muffy' look-a-like (nearly identical to your find above) leaning against a dumpster during our annual clean-up week. Except for the obvious ruptured rear tire, it looked virtually unridden. Not giving it a second glance, I turn my back and began walking away when I remembered a 50ish neighbor lady mentioned to me that she thinking about "getting back into cycling", but didn't have a bike. With that thought still in my head, I turned around and proceeded to haul the damn thing back home. Unable to locate a matching whitewall, I opted to just replaced the failed tire & tube with what I had handy, and deliver it. I've since moved so no clue if she ever rode it,.. or even still has it.I must learn not take any more strays home with me!
I killed the BBS02 with my fat ass and hmm..possibly but it was a different one that I have since sold.Curious the reasons for landing on a hub motor from the BB mid-drive set up? Did your first set up have the hub motor too?
This one grew down to be comfortable.Yeah, kind of seems that the second picture and the third one got mixed up.
Neat to see a bike grow up.![]()
That bike rips! Very stable at high speed, too, unlike my other builds.I 'liked' a hub motor! My mind must be opening![]()
Yes there are limits for all machines. I have a motorcycle that will do 300km/h but I've rarely had it over 200, and that on a very predictable few bits of straight road with no traffic around. I wouldn't dream of going max speed on it but it seems common on ebikes which are a hell of lot more unstable. What ebike uses wind forces to plant itself firmer on the road for example? Not that that really works under 150k anyway. I can 45 km/h on my bike and over bumps it will dance like a teenager on ecstasy. Very unsettling. You have to spend thousands to get proper suspension on them and my rear shock and forks are just not in that league. I couldn't imagine riding a fast hardtail on the roads around here. Though once I was ignorant enough to consider it.I was slaloming at top speed, and damn! You sneeze wrong and it could go very very wrong.
Not sure if that "nimble" is a good thing.
